Sonicfrog Posted April 9, 2011 Share Posted April 9, 2011 Anyone swapped one for the other. One of the mounts on the 83 Brat is hosed, and I'm finding it impossible to find EA 81 mounts. I have found some EA 82s and I've read that they might fit. Anyone had any experience with this problem / solution??? Link to comment Share on other sites More sharing options...
bratman18 Posted April 10, 2011 Share Posted April 10, 2011 I had to use EA82 mounts on my EA81. They aren't the same, but if you cut and re weld them the work. I can't remember the exact spot they need to be cut but I know it is possible, and it does work great 1 Link to comment Share on other sites More sharing options...
bratman18 Posted April 10, 2011 Share Posted April 10, 2011 You will see if you try to bolt them onto the motor how they don't quite bolt on, and then you can tell where the need to be cut, and modified Link to comment Share on other sites More sharing options...
92_rugby_subie Posted April 10, 2011 Share Posted April 10, 2011 Try RockAuto.Com Its pretty popular and reliable and they should have the part you need. I got one for my old 83 Wagon. You even get a neat little refrigerator magnet. Link to comment Share on other sites More sharing options...
MilesFox Posted April 10, 2011 Share Posted April 10, 2011 one end of the mount bolts on, but the other end is flat on the ea82 mount, and the ea81 is bent at an angle to bolt up. or the other way around. it has been 10 years since i did such a thing, but i remember something like that one way or the other Link to comment Share on other sites More sharing options...
Dallasooby Posted April 10, 2011 Share Posted April 10, 2011 Dam Miles... You know whats up... You helped me.. my subie is almost ready for a lift.... lol:eek: Link to comment Share on other sites More sharing options...
Uberoo Posted April 10, 2011 Share Posted April 10, 2011 try 3m window weld. its black uruthane.You have to use a calking gun to apply it,and it HAS TO BE WARM.like leave the container in hot water for like 30 minutes. just use that and glue your mount back together.let it dry for a day minimum (2-4 days is ideal).All said and done it should hold for about a year or so.More if you arnt heavy on the throttle at all times... Link to comment Share on other sites More sharing options...
Sonicfrog Posted April 10, 2011 Author Share Posted April 10, 2011 Uberoo said: More if you arnt heavy on the throttle at all times... Well... So much for that idea!! Link to comment Share on other sites More sharing options...
92_rugby_subie Posted April 10, 2011 Share Posted April 10, 2011 I found motor mounts on RockAuto for your 1983 Brat for like 12-13 bucks or I think it was like 34.95 for both sets? I used them before, I might still have one of my motor mounts for my 83 wagon, but I dont know if that would work, I bought two and I really only needed one. Link to comment Share on other sites More sharing options...
MaddCelt Posted April 10, 2011 Share Posted April 10, 2011 I'm parting out my 81 Brat. I know where the mounts are, do they bolt onto the frame or are welded? (Not looked at them aside from unbolting the engine.) Link to comment Share on other sites More sharing options...
Sonicfrog Posted April 11, 2011 Author Share Posted April 11, 2011 Well, I ended up finding them at RockAuto. They were $34 each. I somehow screwed up the search the first time. But thanks for the offers guy. Appreciate it. Link to comment Share on other sites More sharing options...
92_rugby_subie Posted April 11, 2011 Share Posted April 11, 2011 34.95 each? Are you sure? That seems awfully high for just one of them when the other ones (including one I bought) were like 12 bucks. Link to comment Share on other sites More sharing options...
