pearlm30 Posted April 11, 2011 Share Posted April 11, 2011 I had a tube of subaru OEM grey sealant and I used it a few times before, I sealed the oil seperator plate couple of days ago but I checked this afternoon and its still wet/tacky. Temp here was about from 38 to 50F How long is it for it to dry??? Did I used too much of the sealant? or could it be bad? Thanks in advance Quote Link to comment Share on other sites More sharing options...
Crazyeights Posted April 11, 2011 Share Posted April 11, 2011 It may only cure in the absence of oxygen. It's probably fine. Quote Link to comment Share on other sites More sharing options...
Rooster2 Posted April 11, 2011 Share Posted April 11, 2011 I suspect the low temps of 38-50 degrees keeps the sealant soft. You might want to warm up the area with a hair dryer, if a heated garage is not available. I am thinking that will harden the sealant. Quote Link to comment Share on other sites More sharing options...
ShawnW Posted April 11, 2011 Share Posted April 11, 2011 I prefer the Red Fujibond for that application. Quote Link to comment Share on other sites More sharing options...
