ea81 hitachi carb missing choke pieces
I have an 81 brat with an ea81. the car has trouble starting and idling until its warmed up. I narrowed it down to the carb. it's missing the automatic choke cover and many components. I was going to get a weber eventually, but i would like to have some option of an inexpensive fix, so i can get it smogged. I was checking out rebuild kits, but they don't include the pieces i need. any ideas?
I believe you can use parts from either the Hitachi 2 barrel EA71 carbs or the Hitachi 2 barrel EA81 carbs. Find someone who is doing a Weber swap and buy their old carb from them for parts. Of if you source up a good stock carb for not a lot, swap it on, should be pretty straight forward.
Carbs to watch out for are the Carter-Weber single barrel EA81 carb, Hitachi 2 barrel EA81 computer controlled carb and the Hitachi 2 barrel EA82 carbs
