Dallasooby Posted April 15, 2011 Share Posted April 15, 2011 I love this car.. no matter what i do to it.. it keeps goin... Link to comment Share on other sites More sharing options...
Dallasooby Posted April 15, 2011 Author Share Posted April 15, 2011 I gave her a new oil change and some sea foam treatment.. adjusted the throttle cable down to open up the throttle.. and she runs like a bat outa hell... almost got er up to 95 today,, lmao Link to comment Share on other sites More sharing options...
Dallasooby Posted April 15, 2011 Author Share Posted April 15, 2011 Tick tick tick tick... ddddd .... prrrrrrrrrnnnn at 95 Link to comment Share on other sites More sharing options...
el_freddo Posted April 15, 2011 Share Posted April 15, 2011 What have you done to your subi, is it bog standard or have you tweaked a few things?? I'm not sure how to interpretate those sounds you're trying to make, did something bad happen or did the ticking lifters go quiet at 95mph? Cheers Bennie Link to comment Share on other sites More sharing options...
The FNG Posted April 15, 2011 Share Posted April 15, 2011 I wish I felt the same way right now.... Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted April 15, 2011 Share Posted April 15, 2011 if... el_freddo said: ... the ticking lifters go quiet at 95mph? ... ...Then the Oil pump is Worn... and if the T.O.D. is sung for too much time, the Hydro Lifters will go Worn too... But That Trends to be somehow "Usual" on EA82's... Gotta Lovin' those Cars! Kind Regards. Link to comment Share on other sites More sharing options...
gokoolab Posted April 15, 2011 Share Posted April 15, 2011 Does adjusting throttle cable down really give u more power? Are u just adjusting idle? Will u idle at higher rpm now? Link to comment Share on other sites More sharing options...
1982gl4 Posted April 16, 2011 Share Posted April 16, 2011 gokoolab said: Does adjusting throttle cable down really give u more power? Are u just adjusting idle? Will u idle at higher rpm now? It does when it's adjusted so poorly that it doesn't open all the way Link to comment Share on other sites More sharing options...
6 Star Posted April 16, 2011 Share Posted April 16, 2011 Dallasooby said: Tick tick tick tick... ddddd .... prrrrrrrrrnnnn at 95 Rislone (don't know if thats spelled right) will fix sticky lifters and quit the ticking. Link to comment Share on other sites More sharing options...
Dallasooby Posted April 16, 2011 Author Share Posted April 16, 2011 I wasn't gettin full throttle. I was wondering why it had no power.. I had almost a half inch slack in the cable.. I replaced the mickey mouse gasket in the oil pump.. that didn't help the TOD, it kinda comes and goes.. probably need to adjust the HLA's and the little o rings everyone talks about. Do i need to remove the engine to do that ? Link to comment Share on other sites More sharing options...
