April 16, 201115 yr I got out the fluke and here is what I found. Karolyn/STI Values #1 cord: 1.553 kΩ #2 cord: 2.520 kΩ #3 cord: 1.667 kΩ #4 cord: 2.668 kΩ Factory Resistance values Per Subaru Manual. #1 cord: 7.1 — 12.1 kΩ #2 cord: 12.1 — 19.9 kΩ #3 cord: 7.7 — 13.0 kΩ #4 cord: 12.3 — 20.2 kΩ These wires are possibly inappropriate with approximately 1/4-1/5 th of the factory resistance. But possibly this could be good if the better wires will fit . Now I want to measure the stock wires to be sure of what they really read.
April 16, 201115 yr Author I put them in and although not a perfect fit ( the protective silicone floating tubes are a little too long on the wires and bunch up in the raceway, suppose I could trim them ), I am other wise happy with them so far. I went around the hood for a test drive in first gear. The car felt very solid revving . Interestingly here are the stock Ω values as pulled from the car. 1 8.11 KΩ 2 13.84 KΩ 3 8.7 KΩ 4 12.58 KΩ
April 17, 201114 yr Author STI in this case stands for Spark Transfer International. http://www.karlynsti.com/Folders/Karlyn_STI_Ignition_Wire_Sets.htm
