1-3-2-4 Posted April 16, 2011 Share Posted April 16, 2011 So I will be buying my tranny jack next week and I need 2 pair of jack stands. I was looking at getting the 6 ton set from HF due to it's lift range http://www.harborfreight.com/automotive-motorcycle/jack-stands/6-ton-jack-stand-set-38847.html It's min height is like the max lift for many jacks My concern is having enough lift to get the tranny from under the car.. Is the 6 ton overkill or can I get by with the 3 ton with it's 16 3/4" lift? Link to comment Share on other sites More sharing options...
93Newbaru Posted April 17, 2011 Share Posted April 17, 2011 I've always used the 6 tonners on everything. They are overkill, but overkill is good. Larger pad, larger surface area on the bottom etc. If money is tight you could skip the trans jack and buy the 6 tonners and be a little safer while under the vehicle. I've always just used a floor jack when removing transmissions anyway, and with a little modification and maybe a strap you'd be more than set. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted April 17, 2011 Share Posted April 17, 2011 I use the 6 ton's when I do tranny's. Don't get anything smaller. Typically I have to use a block of wood on my shop jack for the last extra bit of height needed to do a tranny. GD Link to comment Share on other sites More sharing options...
1-3-2-4 Posted April 17, 2011 Author Share Posted April 17, 2011 hah I think I will have to search for some wood I had planned to get the trans jack and the jack stands at the same time. Link to comment Share on other sites More sharing options...
MilesFox Posted April 17, 2011 Share Posted April 17, 2011 the trick will be to jack the car up from one side. this will get you up to get the trans out without the whole car being that high you will want the 3 ton jack. scissor jacks and the little stupid larin awlmart/autozone jacks just wont cut it. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted April 17, 2011 Author Share Posted April 17, 2011 I need to put the car on the stands front and back to test something after the transmission is back in. Link to comment Share on other sites More sharing options...
Scoobywagon Posted April 17, 2011 Share Posted April 17, 2011 Might I suggest this.... Link to comment Share on other sites More sharing options...
1-3-2-4 Posted April 17, 2011 Author Share Posted April 17, 2011 Ha I dont need to go that high but must be sweet Link to comment Share on other sites More sharing options...
abaton6 Posted August 11, 2011 Share Posted August 11, 2011 So I will be buying my tranny jack next week and I need 2 pair of jack stands. I was looking at getting the 6 ton set from HF due to it's lift range http://www.harborfreight.com/automotive-motorcycle/jack-stands/6-ton-jack-stand-set-38847.html It's min height is like the max lift for many jacks My concern is having enough lift to get the tranny from under the car.. Is the 6 ton overkill or can I get by with the 3 ton with it's 16 3/4" lift? When I put a car on jack stands, I always try to knock it off the stands before I get under it. Makes me feel better. I wouldn't buy stuff from harbor freight. It's all made in China. I'll buy American, it makes me feel better. Link to comment Share on other sites More sharing options...
edwardrich01 Posted September 19, 2011 Share Posted September 19, 2011 I used 5 tunners... Link to comment Share on other sites More sharing options...
nipper Posted September 19, 2011 Share Posted September 19, 2011 I use the three ton ones from sears myself. That is three tons per set which is more then enough for almost any car or suv. They are cheap and a good name Link to comment Share on other sites More sharing options...
mcbrat Posted September 19, 2011 Share Posted September 19, 2011 I have some home-made ones I found at a garage sale for $2. they are made from heavy 3" tube that are split into 3 sections at the bottom, peices are bent out to form a tripod, then bars welded in between them for support. upper sections are slightly smaller diameter tube, then there's holes drilled in both for adjustments with a grade 8 bolt stuck thru... then just lay underneath the car, pull the trans up onto your chest, and bench press it into place... arms get a bit tired after couple hours of trying to line up the pilot bearing and shaft though Link to comment Share on other sites More sharing options...
