EA82 control arm bushings - which ones?
Hi guys,
I want to replace the bushings on my control arms on my 1987 GL wagon. I have the ones for the radius rods ready to go, but I can't really see the pressed in bushings to verify what I need. Can someone post a link or a Subaru part number for these?
Thanks
I am in the process of sourcing aftermarket bushings. There are part numbers for 'super pro poly' bushings if you can find a vendor.
NAPA carries oem replacement bushings, and if you want to try to source urethane bushings, you might get them from energy suspension if you have dimensions. It's worth trying to find if youare going through the labor.
you should be able to get apart number from the dealer if you supply your VIN
Right on, thanks Miles. I ordered a bunch of raybestos bushings for my steering rack and radius rods from rockauto. The boxes said raybestos on them but it was a subaru branded part inside with subaru numbers... FYI.
there were ea81 and ea82 in america from 85-89. to disambiguate, you can try searching for 1990 LOYALE, as these are the same part/design/dimension, but you eliminate the possibility of getting an ea81 part instead.
  • 1 year later...
FYI, here is a great source. Outback Technolgies USA they have Polyurethane Suspension Bushings http://obtusa.com/
Here are some part numbers for ref, the pricing is about 2years old and please double check part numbers with them.
Ea82 control arm kit SPF1691K. $35+shipping
Trailing arm complete bushing kit SPF1144K $89+ shipping
