bigjim5551212 Posted March 6, 2004 Share Posted March 6, 2004 On my 88 Turbo EA82, there appears to be no timing marks on the front pulley. There is a rubber cover on the back of the motor and I see the cast in pointer in the engine block. But for the life of me, I cant see any marks on the flywheel. I think the timing is ok, since it pings on boost on regular gas and it doesnt on premium. Any comments? Link to comment Share on other sites More sharing options...
calebz Posted March 6, 2004 Share Posted March 6, 2004 Your timing should be 20 BTDC.. the marks are on the flexplate(under that plug on top of the tranny).. turn the motor over by hand until you see them, they are there.. there's actually 2 sets.. one is just 3 lines.. don't use those.. they are for cam timing... the other set has numbers every 5 (?) degrees.. remember to plug in the green connectors under the dash when doing your timing. Link to comment Share on other sites More sharing options...
myossfeece Posted March 6, 2004 Share Posted March 6, 2004 NOOOOOOOO!!!!! its 25 twenty-five degreees for TURBO spfi ois 20 deg:o Link to comment Share on other sites More sharing options...
mdjdc Posted March 6, 2004 Share Posted March 6, 2004 You are wrong I have two 88 turbos and they both say that timing is 20 degrees BTDC on the sticker under the hood. Link to comment Share on other sites More sharing options...
calebz Posted March 6, 2004 Share Posted March 6, 2004 85-86 Turbo is 25 degrees. 87 and later is 20. I didn't give the numbers for 85-86 because the guy who originally posted has an 88. Myoss, My brutha.. Invest in an FSM.. they are full of all sorts of useful information. Link to comment Share on other sites More sharing options...
nutt7 Posted March 7, 2004 Share Posted March 7, 2004 bump calebz Link to comment Share on other sites More sharing options...
myossfeece Posted March 7, 2004 Share Posted March 7, 2004 hey calebz miles fox originally posted as me but I was there with him and we both said NOOO it is 25 deg btdc. But you were correct in your call. I wasn't aware of that and in a effort to prove you wrong I went out to jims garage and peeped his 88 full time turbo wagon and then in disbelief I went over to an 87 rx and proved myself wrong it is in fact 20 deg. btdc +/- 2 deg. Good call, hey you learn somethin new every day!! Link to comment Share on other sites More sharing options...
calebz Posted March 7, 2004 Share Posted March 7, 2004 lol.. learnin is what its all about:D Link to comment Share on other sites More sharing options...
MilesFox Posted March 7, 2004 Share Posted March 7, 2004 jims car doesnt have the original hood, but anyway look there for ign timing if its original sorry about posting under the wrong name(logout next time!) i will investigate that myself, dam, where can i get an FSM? Link to comment Share on other sites More sharing options...
WJM Posted March 8, 2004 Share Posted March 8, 2004 i ran my rx on 25 deg. Link to comment Share on other sites More sharing options...
speedbump Posted March 8, 2004 Share Posted March 8, 2004 set my new engine to 25 deg and it pings like a sum b&$#% whe I punch it.Its a 1990,with an 86 harness and ecm.Set it to 20deg? Link to comment Share on other sites More sharing options...
MilesFox Posted March 8, 2004 Share Posted March 8, 2004 yeah 20 for later models Link to comment Share on other sites More sharing options...
iluvdrt Posted March 8, 2004 Share Posted March 8, 2004 my 87 is supposed to be 20, but i have it a 15. Link to comment Share on other sites More sharing options...
NumberOneStunner Posted August 8, 2004 Share Posted August 8, 2004 Now you've all got me curious cause I just revived my XT after a 2 year stay in Todd Martins field. The old motor was an EA82T in which i had blown a timing belt. When I replaced this (mind you that 2 years ago this motor was way over my head) I threw off the ign timing. Finally got it running, noticed it bogging down after a mile or so, started messing with the disty and subsequently blew both the ECU and the ignition module. I didn't know at the time anything about this car and subarus in general (hence the 2 year stay in the field). When all was finally said and done I swapped a MPFI N/A motor out of an 88 GL wagon into the car after I got rid of the 86 MPFI Turbo motor. As far as I knew the timing was 25 deg for my old 86 turbo motor so that's what I used but now the motor knocks even on premium pump gas. I was already going to dump a few degrees of timing to solve this but I was wondering what I did wrong. This would explain it. So 87 and after are 20 deg before TDC huh?? I'm gonna try it and see how it goes. Later guys. Link to comment Share on other sites More sharing options...
rallyruss Posted August 8, 2004 Share Posted August 8, 2004 I was caught in the bad info crew as well. the chilton book I used showed 25deg for my 87. but it likes the correct 20 deg much better. Link to comment Share on other sites More sharing options...
oddcomp Posted August 8, 2004 Share Posted August 8, 2004 mine says 20 but i run it at 17-18 ish it likes it much better.. but i run 10 psi also and cheap gas in a few days no more disty w00t Link to comment Share on other sites More sharing options...
