Differant EA81 Rear Tersion bars?
in all of the ones i have come across, i have not noticed a difference.some had a stiffener on top, and some did not.(kinda like a welded on piece of rod....)
whatcha up to?
i once had a brat with a tow hitch on the back that was bolted through el mustacho....don't know how much that helped:lol:..cheers, b
whatcha up to?
Well I had to cut my stock ones to get them out (trying to get a stiffer rear suspension). So I went to the junk yard and picked some up out of a wagon. And now i found that the right rear was rubbing on the fender. Thinking that the torsion bar wouldn't hold the same amount of weight was the cause... Found tonight that I have a broken lift block bolt that caused the rear suspension to roll back when accelerating and on a right hand corner... ****ing bolt!!!!!!
Now with that being said... All the 2wd cars sit a lot lower to the ground, on my lowered brat I am building, could that rear suspension be adapted to the 4wd trailing arm? So hence a lower profile... Just throwing that out there since we are talking about torsion bars and such.
