rx35285 Posted April 24, 2011 Share Posted April 24, 2011 Just rebooted the left CVJ on our 98 Legacy. The USRM item by Ed was extremely helpful - made the job quite simple. I didn't have a boot stretching tool so here's a suggestion to add to the suggestion about turning the boot inside out (can't remember the name of the gent who shared that idea) and pulling it over the joint. I cut a plastic funnel to use as an expansion cone and fit it over the axle stub and sprayed it with white grease. I put the inside-out boot in boiling water for a minute then sprayed the inside of it with white grease and pulled it over the funnel and joint. I was surprised how easy it was. Heating the boot in water was easier and safer than using a propane torch for me. Hope this helps someone else. Quote Link to comment Share on other sites More sharing options...
Rooster2 Posted April 25, 2011 Share Posted April 25, 2011 Good suggestion! Quote Link to comment Share on other sites More sharing options...
