1-3-2-4 Posted April 24, 2011 Share Posted April 24, 2011 Does this hose have a check valve in it? (heard it at outback.org That might explain why my vacuum readings were so high? If I can't use that then where else can you check for vacuum? Link to comment Share on other sites More sharing options...
nipper Posted April 24, 2011 Share Posted April 24, 2011 Lets back up a bit. You can only get as much vacume as there is barometric reading, but thats almost impossible on an engine at idle. http://www.classictruckshop.com/clubs/earlyburbs/projects/vac/uum.htm Now what is "too high" and at what condition. And no the PB system can not make you read too much vacume. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted April 24, 2011 Author Share Posted April 24, 2011 Brake booster has a check vavle in it thats why my reading was off Link to comment Share on other sites More sharing options...
nipper Posted April 24, 2011 Share Posted April 24, 2011 still did not answer the question, what was the reading and no it wont cause too high a reading. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted April 24, 2011 Author Share Posted April 24, 2011 The reading in the video? Or the new one I took? Link to comment Share on other sites More sharing options...
nipper Posted April 24, 2011 Share Posted April 24, 2011 And I am om a blackberry with a small screen. Either tell me what it is doong or ill answer it tomorrow when I can see it. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted April 24, 2011 Author Share Posted April 24, 2011 hah I'm on my evo here quick question does your text type out slow here? Anyways here is the link for the test other then the brake booster hose. You can use any other vac line other then the hose that runs to the brake booster. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted April 24, 2011 Author Share Posted April 24, 2011 (edited) *snip Edited April 24, 2011 by 1-3-2-4 Link to comment Share on other sites More sharing options...
nipper Posted April 25, 2011 Share Posted April 25, 2011 There is this word that comes to mind.... it strikes pure horror in some people. other people just look in awe, others wish it could be them, and yet others are non-plused by the word. Live not in fear, as it can be comforting ... NORMAL! 20-25 In Hg is normal for a healthy engine at idle. Link to comment Share on other sites More sharing options...
