lowering springs?
TheSubaruJunkie had some 2wd XT struts and springs on his RX a few years ago.
The reason why the 2wd stuff is longer in the rear is because they mount to the trailing arm where the axle would be on the 4wd setup.
If you want to lower it for the sake of lowering it, just get some Impreza coilover sleeves off of ebay. Cost under $100 usually for a set of four and they are adjustable typically. I have 2 sets; one on my XT6 and the other on my RX.
  • 5 months later...
Where did you find sleeve/spring kits for Subis for under $100? The only thing I've found is Skunk2 kits for WRX for about $300 shipped. Also, what year Imp kits work?
  • 9 months later...
Yes where is a link to these?
