Ricearu Posted April 29, 2011 Share Posted April 29, 2011 So the 90 legacy I bought is great, except for when I corner below 1/2 tank, and only on left hand turns. it cuts out, sputters and sometimes dies dependant on how much fuel is in the tank. I read in the FSM I have that there is a "jet pump" from one side of the tank to the other, strangely enough its supposed to move fuel from the left side to the right (pump) side if i am correct. where is this "jet pump" and how do I replace it? I am also guessing that gas is stuck over there and is why my car only holds "11 gallons"... also, car is FTAWD 5MT Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted April 29, 2011 Share Posted April 29, 2011 The pickup tube/screen has fallen off the pump. Pull the pump/sending unit out and fix it. The jet pump is not likely the problem and in any case you have to drop the tank to get to it. GD Quote Link to comment Share on other sites More sharing options...
Ricearu Posted April 29, 2011 Author Share Posted April 29, 2011 does said pickup tube float? I guess I will wait a day or two and run her down on gas, (I filled up this morning) Quote Link to comment Share on other sites More sharing options...
