jboymechanic Posted April 30, 2011 Share Posted April 30, 2011 1995 Legacy with 2.2 won't start when hot/up to normal running temp. Always starts right up when cold, runs great, but then once it's up to temp, it will turn over and over but not fire up. Let it sit for an hour to cool back down, starts right up. I have good fuel pressure as I just checked when replacing the fuel filter, fuel pump comes on every time I turn the key. I'm guessing this is some sort of sensor malfunction? Link to comment Share on other sites More sharing options...
idosubaru Posted April 30, 2011 Share Posted April 30, 2011 any check engine light? crank or cam sensor will cause no start conditions. get a used one, they don't fail often enough to warrant the high price of new. ignition coil/igniter could be failing too. Link to comment Share on other sites More sharing options...
MilesFox Posted April 30, 2011 Share Posted April 30, 2011 coolant temp sensor. Itls located on the left side of the motor behind the intake on the water crossover tube. ypu can get one at napa Link to comment Share on other sites More sharing options...
Olnick Posted April 30, 2011 Share Posted April 30, 2011 ^+1! Definitely try the Coolant Temperature Sensor. Good luck. Link to comment Share on other sites More sharing options...
naru Posted April 30, 2011 Share Posted April 30, 2011 Leaky injector,perhaps.Try starting w/throttle floored to clear the excess fuel. Check for spark if that doesn`t work. Link to comment Share on other sites More sharing options...
TheLoyale Posted May 1, 2011 Share Posted May 1, 2011 Coolant Temp Sensor FTW, I said it a few days ago way before he posted the thread. I have a used one in my tool box that we're gonna try. Cam/Crank sensors would cause a no start issue even if the engine is ice cold. Link to comment Share on other sites More sharing options...
jboymechanic Posted May 2, 2011 Author Share Posted May 2, 2011 Pulled the CEL codes, CPS and Knock Sensor both manfunctioning. Up on blocks now anyways, doing new rear brakes and parking brake shoes and hardward and Outback struts. Link to comment Share on other sites More sharing options...
MilesFox Posted May 2, 2011 Share Posted May 2, 2011 you can get a code for one thing, compounded by something else. Based on common ocurrence, the CTS is the likely culprit. Link to comment Share on other sites More sharing options...
johnceggleston Posted May 2, 2011 Share Posted May 2, 2011 several years ago there was a similar thread. the guy was able to start the car when hot by pouring water on the cts and cooling it. tricking the engine into thinking it was cool. this may not help, but who knows. if it starts you have identified the problem. if not, it could still be the cts or maybe something else. Link to comment Share on other sites More sharing options...
jboymechanic Posted May 2, 2011 Author Share Posted May 2, 2011 I now have an extra CTS, but I will wait until I replace the CPS and Knock Sensor and see if the issue persists. If so, I will replace the CTS as well, but I like to know the exact cause of a problem before I just replace everything. Link to comment Share on other sites More sharing options...
MilesFox Posted May 4, 2011 Share Posted May 4, 2011 By tis approach, you are contradicting yourself. Start with the CTS, and i bet your knock sensor code goes away. Replace the free part first, before dropping 80 bucks on a knock sensor you dont need Link to comment Share on other sites More sharing options...
jboymechanic Posted May 5, 2011 Author Share Posted May 5, 2011 (edited) Replaced the CPS today, it was about $25 from RockAuto. Let the car get hot and shut it off, restarted several times right away. I already ordered the Knock sensor, wasn't to expensive ($45 again from RockAuto) so I'll just keep that and the CTS handy in the car with some basic hand tools just in case. Oh, and no more CEL showing up any more either. Edited May 5, 2011 by jboymechanic added comment Link to comment Share on other sites More sharing options...
TheLoyale Posted May 5, 2011 Share Posted May 5, 2011 Replaced the CPS today, it was about $25 from RockAuto. Let the car get hot and shut it off, restarted several times right away. I already ordered the Knock sensor, wasn't to expensive ($45 again from RockAuto) so I'll just keep that and the CTS handy in the car with some basic hand tools just in case. Oh, and no more CEL showing up any more either. I was betting it was the CPS, as mine did the same thing last year, it would also die randomly at stop lights Lol. But yeah, I replaced everything to start fresh, Cam/crank sensor, CTS, Knock sensor. You need to do plugs and wires on that too, Why didn't we do them when we put the motor back in? Link to comment Share on other sites More sharing options...
jboymechanic Posted May 5, 2011 Author Share Posted May 5, 2011 Not sure, but I'll get to plugs and wires eventually. Hoping the rest of the parts come tonight so I can wrap up the rear brake job. Link to comment Share on other sites More sharing options...
