Spark Plug ground is Greenish.. But why ??
wanted to change out the plugs, only to find that I had 2 Denso and 2 NGK's ..all 4 plugs are correct for the 1990 loyale..installed on each side 1 ngk and 1 denso and then drove 1 hr ...out of curiosity I pulled the plugs and the denso were grayish in color through out while the ngk's were more whiteish with a greenish colored ground strap..switched them around and drove another 1/2 hr..pulled the plugs once more..basically no change to the plugs except that the green color was a little darker ..spark plug charts make no mention of this greenish tint..any ideas..timing, or are the plugs to hot??
Not sure about your case, but green usually indicates oxidation of copper. If you want a reliable indication of your cars fuel/air ratio, clean the plugs and do a full throttle run in 3rd and kill the engine before lifting your foot off the pedal.
Hpw old are the spark plug wires
