MaddCelt Posted May 1, 2011 Share Posted May 1, 2011 (edited) This was the sound I was greeted with then I stopped at the local ice cream stand and the second one was when I got home. Aside from the noise everything is running good and no codes. http://www.mediafire.com/?uulcn8bvyb1pem8 http://www.mediafire.com/?2f98p91cs51qqlp Edited May 2, 2011 by MaddCelt Better links Link to comment Share on other sites More sharing options...
Ricearu Posted May 2, 2011 Share Posted May 2, 2011 that's no piston slap. that sounds bottom end... sorry to say it. sounds like a rod bearing. Link to comment Share on other sites More sharing options...
ericem Posted May 2, 2011 Share Posted May 2, 2011 damn that sucks ya definitely. Even possibly a idler/ tensioner can cause that. Expierienced that on a forester 2.5 guy claimed bottom end found the timing belt tensioner was flapping around. Link to comment Share on other sites More sharing options...
Fairtax4me Posted May 2, 2011 Share Posted May 2, 2011 Did you do timing belt work to this engine? (too lazy to look up your other thread) Check your crankshaft pulley, it may have a case of "the wobbles", from the bolt not being tight enough. Link to comment Share on other sites More sharing options...
MaddCelt Posted May 2, 2011 Author Share Posted May 2, 2011 Sorry for the lack of further information. The sound is from the drivers side, sounding from the #4 cylinder area. I have had piston slap on that side from the get go (rebuilt engine) but this just occured yesterday. Performance has not been effected that I can tell. Link to comment Share on other sites More sharing options...
idosubaru Posted May 2, 2011 Share Posted May 2, 2011 timing belt tensioners can sound terrible and resemble rod knock or more sinister items. remove the drivers side belt cover and you'll be able to see it flopping around. Link to comment Share on other sites More sharing options...
MaddCelt Posted May 2, 2011 Author Share Posted May 2, 2011 Ok, just got back from pulling the timing cover off. Fired it up and let it run. Little to no slap for about 5 mins. The idle lowered then the knock started but very inconsistant. The pulleys are sound and solid. The knock is coming from #2 area and sounds more in the area of the valves. Didn't have a screwdiver long enough to get a better listen. Link to comment Share on other sites More sharing options...
Suba9792 Posted May 3, 2011 Share Posted May 3, 2011 sounds like a valve meeting piston to me. Link to comment Share on other sites More sharing options...
nipper Posted May 4, 2011 Share Posted May 4, 2011 This is what happend to Blu before a rather impressive and spectacular rod failure. nipper Link to comment Share on other sites More sharing options...
