The Dude Abides Posted April 5, 2012 Author Share Posted April 5, 2012 LOL, busy boy Link to comment Share on other sites More sharing options...
mcbrat Posted April 11, 2012 Share Posted April 11, 2012 and by installed, I just mean:In the engine bay, bolted to D/R trans, engine mounts bolted in. still plenty more work ahead DONE speedo cable hooked up DONE clutch cable installed DONE radiator & hoses DONE electric rad fan DONE power steering pump installed DONE exhaust bolted on DONE brake booster vac line hooked up DONE power steering lines adapted and connected DONE torque pressure plate bolts DONE heater hoses installed DONE starter installed DONE new coil mounted DONE ballast resistor installed new plug wires weber installed alt/PS belts fuel pump vac connections disty/coil/choke/fan/fuel pump wiring trans gear oil engine oil coolant PS fluid evacuate AC system and remove and probably more stuff I'm forgetting.... and again... a little more completed. Link to comment Share on other sites More sharing options...
The Dude Abides Posted April 11, 2012 Author Share Posted April 11, 2012 Jeez man remember to get some sleep. Link to comment Share on other sites More sharing options...
mcbrat Posted April 15, 2012 Share Posted April 15, 2012 still plenty more work ahead DONE speedo cable hooked up DONE clutch cable installed DONE radiator & hoses DONE electric rad fan DONE power steering pump installed DONE exhaust bolted on DONE brake booster vac line hooked up DONE power steering lines adapted and connected DONE torque pressure plate bolts DONE heater hoses installed DONE starter installed DONE new coil mounted DONE ballast resistor installed DONE alternator and belt installed DONE battery hooked up weber installed PS belt fuel pump vac connections disty/coil/choke/fan/fuel pump wiring trans gear oil engine oil coolant PS fluid evacuate AC system and remove and probably more stuff I'm forgetting.... found the check connector for the fuel pump and ready to get the coil and disty hooked up... Link to comment Share on other sites More sharing options...
The Dude Abides Posted April 15, 2012 Author Share Posted April 15, 2012 You found time to do this with the monsoon. Link to comment Share on other sites More sharing options...
TheLoyale Posted April 15, 2012 Share Posted April 15, 2012 Batin the hatches people! Oh my!! Link to comment Share on other sites More sharing options...
mcbrat Posted April 15, 2012 Share Posted April 15, 2012 You found time to do this with the monsoon. yeah. after I scrambled to get the Forester and Baja in the garage (after hearing quarter sized hail in DSM) , I had some time to study the FSM and find the alt as I had taken that off some time ago... the storm didn't seem too bad here at least but I don't hear lots of weather... this house is actually insulated and helps deaden the sounds. the old house had nearly zilch for insulation... Link to comment Share on other sites More sharing options...
mcbrat Posted April 16, 2012 Share Posted April 16, 2012 the starter moved for the first time in a while... just a half second though to make sure the IGN switch was working Link to comment Share on other sites More sharing options...
mcbrat Posted April 17, 2012 Share Posted April 17, 2012 still plenty more work ahead DONE speedo cable hooked up DONE clutch cable installed DONE radiator & hoses DONE electric rad fan DONE power steering pump installed DONE exhaust bolted on DONE brake booster vac line hooked up DONE power steering lines adapted and connected DONE torque pressure plate bolts DONE heater hoses installed DONE starter installed DONE new coil mounted DONE ballast resistor installed DONE alternator and belt installed DONE battery hooked up DONE weber installed DONE fuel pump swapped DONE vac connections DONE PCV hookup DONE new plug wires disty/coil/choke/fan/fuel pump wiring PS belt trans gear oil engine oil coolant PS fluid evacuate AC system and remove and probably more stuff I'm forgetting.... really close now! Link to comment Share on other sites More sharing options...
The Dude Abides Posted April 17, 2012 Author Share Posted April 17, 2012 Yea the next item is going to be the hardest. Link to comment Share on other sites More sharing options...
mcbrat Posted April 18, 2012 Share Posted April 18, 2012 It's Alive! http://www.facebook.com/v/434747213205345 still to complete... choke wiring Temp gauge wiring evacuate AC system and remove I was gonna wire in the tach, but it's a DL so no tach... might need to get an oil pressure switch for the dummy light too, as the pump has the sender for a GL Oil Pressure Gauge.... DONE speedo cable hooked up DONE clutch cable installed DONE radiator & hoses DONE electric rad fan DONE power steering pump installed DONE exhaust bolted on DONE brake booster vac line hooked up DONE power steering lines adapted and connected DONE torque pressure plate bolts DONE heater hoses installed DONE starter installed DONE new coil mounted DONE ballast resistor installed DONE alternator and belt installed DONE battery hooked up DONE weber installed DONE fuel pump swapped DONE vac connections DONE PCV hookup DONE new plug wires DONE disty/coil/fan wiring DONE PS belt DONE trans gear oil DONE engine oil DONE coolant DONE PS fluid TEMP fuel pump wiring Link to comment Share on other sites More sharing options...
mcbrat Posted April 18, 2012 Share Posted April 18, 2012 oh, and the alternator Denis put in previously is putting out 14.1v so it's good. Link to comment Share on other sites More sharing options...
The Dude Abides Posted April 18, 2012 Author Share Posted April 18, 2012 (edited) I could cry. Wire in the Tach, lol cummon. Its beyond a DL now. Edited April 18, 2012 by The Dude Abides Link to comment Share on other sites More sharing options...
mcbrat Posted April 18, 2012 Share Posted April 18, 2012 maybe I'll bust apart an ea81 cluster and duct tape the oil pressure and tach to your dash then it will be a GL I'm going to add a kill switch to your dash for the grounding of the fuel pump relay (used to happen through the ECU, but since thats gone now....) Link to comment Share on other sites More sharing options...
The Dude Abides Posted April 18, 2012 Author Share Posted April 18, 2012 Hey its got temp and fuel. Tach, please real men know when to shift i dont need a gauge to tell me that. Link to comment Share on other sites More sharing options...
ShawnW Posted April 19, 2012 Share Posted April 19, 2012 Nice Job Mick! Looks great. Link to comment Share on other sites More sharing options...
mcbrat Posted April 19, 2012 Share Posted April 19, 2012 Fuel pump permanent wiring in Temp gauge wiring in choke wiring in battery hold downs in hood shut with ac comp in spare area readt to have the r12 removed. It definitely is gonna need exhaust! Link to comment Share on other sites More sharing options...
The Dude Abides Posted April 19, 2012 Author Share Posted April 19, 2012 Eeeeeek, is it pretty bad. Link to comment Share on other sites More sharing options...
mcbrat Posted April 19, 2012 Share Posted April 19, 2012 Eeeeeek, is it pretty bad. well, since there's no muffler on it it hard to tell if it's leaking at the Y pipe junction... but based on the way it flexes, I'd say it's rusted through... you're gonna need a new stock Y pipe anyway. it's mounted enough to get it home I'll be home all day Saturday for pickup I'll be clearing the garage for the city wide garage sale day.... I even tucked up your wiring under the dash and reconnected your CB. the trans didn't have any knobs on it when I got it (already gone...) so I put on the one I pulled off the SS, and for the D/R selector, I tapped another spare t-case knob I had from something else... Link to comment Share on other sites More sharing options...
The Dude Abides Posted April 19, 2012 Author Share Posted April 19, 2012 Stock ea81 or would a ea82 work. Link to comment Share on other sites More sharing options...
mcbrat Posted April 19, 2012 Share Posted April 19, 2012 Stock ea81 or would a ea82 work. stock ea82 for the exhaust. Link to comment Share on other sites More sharing options...
The Dude Abides Posted April 19, 2012 Author Share Posted April 19, 2012 Already hearing it from home, do you want me to get it this weekend. Link to comment Share on other sites More sharing options...
The Dude Abides Posted April 19, 2012 Author Share Posted April 19, 2012 LOL the last time the exhaust was mounted just enough it almost killed someone. Link to comment Share on other sites More sharing options...
mcbrat Posted April 19, 2012 Share Posted April 19, 2012 Already hearing it from home, do you want me to get it this weekend. yes if possible. I'll be around all day Saturday trying to cleanup the garage... Get a ride up with the guy who wants the engien/trans. I'm taking it to get the AC evacuated tomorrow afternoon. maybe today if I can leave work early enough. Link to comment Share on other sites More sharing options...
mcbrat Posted April 19, 2012 Share Posted April 19, 2012 LOL the last time the exhaust was mounted just enough it almost killed someone. it's on solid, but the clamping force is reduced on the side that the flange is rotated on... I had to use my bottoming tap to clean up and cut a few more threads since it seems a little loose when I put the studs in... but, the good thing with this engine is that the ASV spacers are still there, and can be tapped if the aluminum threads give it up in the head.... Link to comment Share on other sites More sharing options...
