Loyale90 Posted May 7, 2011 Share Posted May 7, 2011 buyin a new clutch and i havent replaced it before. im kinda tight on cash and was wondering if i need the whole clutch kit or can just get the disc and bearings? Link to comment Share on other sites More sharing options...
87.5ea82txt Posted May 7, 2011 Share Posted May 7, 2011 I got a kit from oreillys for a fair price with a lifetime warrenty. Good clutch. Just have a friend that works at a machine shop plane the flywheel. Link to comment Share on other sites More sharing options...
WoodsWagon Posted May 8, 2011 Share Posted May 8, 2011 I have found pressure plates to have lost their spring tension so it slipped like a bad clutch. I put a new disk in and a used pressure plate from a known good donor car, and it worked great. I then took the disk from the slipping clutch and tossed it in a 2.5l WRX, where it's been working great. So a slipping clutch may not be a worn out disk, it could be a failing pressure plate. That's why it's best to replace the pressure plate along with the disk and bearings. Link to comment Share on other sites More sharing options...
