Dual SPFI?
I know this sounds crazy.....but i was thinking about this today...one Throt body for each head, and Air flow meter....to achieve Dual SPFI! Ofcourse, this would be a replacement for the stock EA82 SPFI with the single port heads....
More airflow to complement the Delta cams and such....
Ofcourse, a custom manifold would be needed for this.
You seen the size of the shared intake ports on SPFI? Teeny. Cheaper & easier to put MPFI heads/intake on, if you can get the CR up. Which is exactly what Subaru themselves did with the (EJ18?), isn't it?
