sa997 Posted May 10, 2011 Share Posted May 10, 2011 . I have a Subaru Impreza 1.6 94. I have two questions. Social the plugin. Black and showed error 35. (canister). I checked it and it correctly. 44 Om. He closes vacuum. Opens, and no liquidity. I did a test with the green connector. Travel in all normal. I wanted to delete the problem connecting two black authors black and green to green. But the problem is not deleted. This is a problem because I have error traveling with Air Conditioner. After 10 minutes. The engine stutters. Check lamp turns on my engine. 2. How can I. As properly since Solenoid valve Link to comment Share on other sites More sharing options...
wtdash Posted May 11, 2011 Share Posted May 11, 2011 From THIS POST: can i exclude this sensor ? Yes. Wire a 100-ohm 2-watt resistor between the ECU's purge control pin and an ignition-switched +12v source. GL, Td Link to comment Share on other sites More sharing options...
