. I have a Subaru Impreza 1.6 94. I have two questions. Social the plugin. Black and showed error 35. (canister). I checked it and it correctly. 44 Om. He closes vacuum. Opens, and no liquidity. I did a test with the green connector. Travel in all normal. I wanted to delete the problem connecting two black authors black and green to green. But the problem is not deleted.
This is a problem because I have error traveling with Air Conditioner. After 10 minutes. The engine stutters. Check lamp turns on my engine.
2. How can I. As properly since Solenoid valve
