Markus56 Posted May 11, 2011 Share Posted May 11, 2011 Hey guys I have a 91 Legacy L with an automatic and i want to transplant cruise control from a parts car onto my car. What is all the stuff i need to pull? I already have the vacuum pump, the servo, the switch, and the control unit. What else do I need? Thanks! Link to comment Share on other sites More sharing options...
wtdash Posted May 11, 2011 Share Posted May 11, 2011 Hi, Do you have the steering wheel lever, too? I'm wondering if the 'roll connector/clock spring' is the same? There may be a different switch actuated by the brake pedal that turns off the Cruise too....if the cruise controller doesn't see that the cruise may not work. Also, you don't have AC or power windows, correct? If you do then something 'just ain't right'. Looking on cars101.com the 'Value Plus' package included cruise/AC/PW. Td Link to comment Share on other sites More sharing options...
Markus56 Posted May 12, 2011 Author Share Posted May 12, 2011 It has the tilt steering wheel, A/C, P/S, and leather seats, but no cruise control. I believe the brake switch is different for CC. 4 wire vs 2 wire. Link to comment Share on other sites More sharing options...
lmdew Posted May 12, 2011 Share Posted May 12, 2011 Yes you will need the brake switch as well. Link to comment Share on other sites More sharing options...
Markus56 Posted May 12, 2011 Author Share Posted May 12, 2011 I kinda figured that. Anything else? Link to comment Share on other sites More sharing options...
