KaraK Posted June 13, 2011 Author Share Posted June 13, 2011 And now, for something completely different.... [2001 H6 3.0] I need to address noise coming from sepentine belt area, hoping that it's just idler/tensioner pulley bearings, and not something more costly. Read in here a while back that the H6 3.0's have this issue... Got a few ????'s.... Haven't priced out the pulleys yet, but my searches revealed changing just the bearings was the way to go... Tips/Advise????? Would both bearings be the same? Got a couple parts #'s from 2 different sources, one is Napa 6203-2rsj, other is Parts Master PM203FF. Are these correct? once I take it apart, don't have another car running right now for trips to the parts store.... Haven't done much Subaru fixing (as this is my first) And the "stupid" Haynes book I have, shows nothing like this H6 (pics must be of only 2.5's) Grossgary advised to remove belt tension, just put a wrench on lower pulley. So.... to put the belt back on, I just tighten that pulley? and tension will be fine?? Nothing like G.M.- where we put a prybar on alternator to tighten?? Link to comment Share on other sites More sharing options...
MilesFox Posted June 13, 2011 Share Posted June 13, 2011 if its like anything like a 2.2/2.5, there is a nut on the pulley to hold it still, loosen it, and there is a bolt with left hand thread to move it up and down. once adjusted, tighten the nut on the pulley. Link to comment Share on other sites More sharing options...
TheLoyale Posted June 13, 2011 Share Posted June 13, 2011 if its like anything like a 2.2/2.5, there is a nut on the pulley to hold it still, loosen it, and there is a bolt with left hand thread to move it up and down. once adjusted, tighten the nut on the pulley. Nope, this is totally different then the EJs. It has a spring loaded tensioner (Kinda like a Dodge 460) where you'd use a wrench on the tensioner bolt to push the tensioner outta the way and releave the tension. Link to comment Share on other sites More sharing options...
TheLoyale Posted June 14, 2011 Share Posted June 14, 2011 Can anyone confirm the Part number for the Idler bearings on the EZ30? Link to comment Share on other sites More sharing options...
KaraK Posted June 17, 2011 Author Share Posted June 17, 2011 Can anyone confirm the Part number for the Idler bearings on the EZ30? Hope someone can confirm part # PM203FF as that's the bearings I bought... I guess we'll find out tomorow...... Link to comment Share on other sites More sharing options...
KaraK Posted June 18, 2011 Author Share Posted June 18, 2011 Tom(TheLoyale)and I changed out the bearings today... All went very well. W/the purchase of a 30mm. socket to pound them out/in, whole job costed about $10. I'm extra very happy! :grin: BigBigBigThank You to Tom!!! You are my friend for life!!!!! Link to comment Share on other sites More sharing options...
