EA81 Dual Range Problem.....HELP!!
On my sons EA81 wagon the transmission just began clunking. It's not a grinding, but an actual clunking when driving in normal 2WD. It's especially prominent just after shifting gears or corning, but it really does it all the time in 2WD. If we pop it into 4WD the clunking goes away and all appears well.
Whats going on? 4WD not fully disengaging? This car is lifted 4" and nothing was really done to modify the 4WD lever or linkage.
Probably the driveshaft. When it's in 2wd the driveshaft is freewheeling, when you pop it in 4wd it's being driven. So it's putting different force on the joints. It will stop the clunking.
When mine went, that was the exact symptoms I had.
