superbrat84 Posted May 17, 2011 Share Posted May 17, 2011 i own a 1984 subaru brat and i have checked the actual speedometer and the cable and those are good i have also put it on jack stands and even sat under the hood while the car was driving and speed shaft in the tranny doesn't turn. can't seem to remove it? do i need a new tranny. i also can't trun it any type of pliers and all data and haynes manual says nothing about this problem. Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted May 17, 2011 Share Posted May 17, 2011 The speedo drive gear/shaft/seal is not serviceable from outside the transmission. You would have to remove the tranny and dissasemble it. Not worth doing with a 4 speed. Just replace it with a 5 speed. GD Quote Link to comment Share on other sites More sharing options...
superbrat84 Posted May 22, 2011 Author Share Posted May 22, 2011 does the 5 speed have the dual range 4x4 Quote Link to comment Share on other sites More sharing options...
NWSubie Posted May 22, 2011 Share Posted May 22, 2011 Yes they do, check out the Ultimate Subaru Repair Manual found on the main page of the web site. Here is the link to do the swap. http://www.indysworld.com/80s/general/USRM/mick-usrm/transmission/5speed.html This link is from the old USRM also found on the main page. You can hunt around the forum also many have done the swap. Quote Link to comment Share on other sites More sharing options...
edrach Posted May 24, 2011 Share Posted May 24, 2011 does the 5 speed have the dual range 4x4 Yes, '85 to '88 GL models (maybe others since I'm not the expert of that) often came with a 5MT dual range transmission. I felt that the '88 version was the best since it might have the least miles on it. Check out bratsrus1; he makes an upgrade kit and did my swap on our '84. Quote Link to comment Share on other sites More sharing options...
superbrat84 Posted May 27, 2011 Author Share Posted May 27, 2011 need help. i bought a 5 speed manual transmission that has the low range and everything and it came off a 1986-1988 Subaru 2 door car its not the just and i think it is the xt model. Any way the 4 wheel drive linkage is in a different place. did i just waste $150 i'm clueless on this because the instructions on the forum said to "just hook up the 4 wheel drive linkage". Please help !!!!!!!!! what are some fixes for the gear selector bushings. (the bushings in the universal joint looking thing) Thanx!!! Quote Link to comment Share on other sites More sharing options...
