87.5ea82txt Posted May 19, 2011 Share Posted May 19, 2011 What have others done in regards to the uneven backsides of the hubs before installing the lugs in the new holes? I've read that people have ground them flat and welded in new material or even ground the lugs, and others do nothing at all and seem to have no problem. Link to comment Share on other sites More sharing options...
bigo1966 Posted May 19, 2011 Share Posted May 19, 2011 Ground the lugs and the hub. I do both. Link to comment Share on other sites More sharing options...
MilesFox Posted May 19, 2011 Share Posted May 19, 2011 you may want to do 21mm lugnuts. Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted May 19, 2011 Share Posted May 19, 2011 I use a milling machine Link to comment Share on other sites More sharing options...
monstaru Posted May 19, 2011 Share Posted May 19, 2011 now welding needed,just grind them down paying attention to the heat.cheers, b Link to comment Share on other sites More sharing options...
87.5ea82txt Posted May 19, 2011 Author Share Posted May 19, 2011 Ill replace the nuts with larger to get better surface area on the rims. Great tip, Miles. Any suggestions on where to get a good deal on lugs and nuts besides the junk yard? My friend works at a machine shop. Is a milling machine pretty quick and easy to set up? If they don't have one of those, what bit do I need to do it on a drill press? I feel the cnc machine is a little overkill. Link to comment Share on other sites More sharing options...
monstaru Posted May 20, 2011 Share Posted May 20, 2011 what ************ing part of grinder did you not understand?:lol:cheers, b Link to comment Share on other sites More sharing options...
