Does anyone know what alternator bearing a 97 legacy uses? If it matters, the alternator was replaced during a recall about 12 years ago.
I know there’s a good chance the rectifier bridge will fail before the bearing does, but i figured i might as well do it since i replaced the idler bearing and PS bearing.
Thanks
It's a 6303 double sealed ball bearing with the following dimensions:
17mm ID x 47mm OD x 14mm W
If there's no play, I might just pop the seals off and regrease the bearing.
The pilot bearing doesn't take much of a load and should be fine.
Awesome, thanks! I may be able to find a new 6203 laying around here somewhere; if not I think i'll just take your suggestion and grease it.
Waste of time. The recalled alt part number at the dealer is only $65 and you will get new brushes, rectifier, and bearings.
Also, replace your belts when they get hard and squeal instead of tightening the hell out of them and blowing all the accesory bearings.
Edited by GeneralDisorder
Waste of time. The recalled alt part number at the dealer is only $65 and you will get new brushes, rectified, and bearings.
Just for future reference, do you have that part number?
