sario Posted May 23, 2011 Share Posted May 23, 2011 Does anyone know what alternator bearing a 97 legacy uses? If it matters, the alternator was replaced during a recall about 12 years ago. I know there’s a good chance the rectifier bridge will fail before the bearing does, but i figured i might as well do it since i replaced the idler bearing and PS bearing. Thanks Quote Link to comment Share on other sites More sharing options...
MilesFox Posted May 23, 2011 Share Posted May 23, 2011 Overtightening the belts can cause bearing failures. I dont think its a common occurrence, but the belt systems o n the newer stuff will allow you to overtighten it much more easily Quote Link to comment Share on other sites More sharing options...
hohieu Posted May 23, 2011 Share Posted May 23, 2011 It's a 6303 double sealed ball bearing with the following dimensions: 17mm ID x 47mm OD x 14mm W If there's no play, I might just pop the seals off and regrease the bearing. The pilot bearing doesn't take much of a load and should be fine. Quote Link to comment Share on other sites More sharing options...
sario Posted May 24, 2011 Author Share Posted May 24, 2011 It's a 6303 double sealed ball bearing with the following dimensions:17mm ID x 47mm OD x 14mm W If there's no play, I might just pop the seals off and regrease the bearing. The pilot bearing doesn't take much of a load and should be fine. Awesome, thanks! I may be able to find a new 6203 laying around here somewhere; if not I think i'll just take your suggestion and grease it. Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted May 24, 2011 Share Posted May 24, 2011 (edited) Waste of time. The recalled alt part number at the dealer is only $65 and you will get new brushes, rectifier, and bearings. Also, replace your belts when they get hard and squeal instead of tightening the hell out of them and blowing all the accesory bearings. GD Edited May 24, 2011 by GeneralDisorder Quote Link to comment Share on other sites More sharing options...
sario Posted May 24, 2011 Author Share Posted May 24, 2011 Waste of time. The recalled alt part number at the dealer is only $65 and you will get new brushes, rectified, and bearings. Also, replace your belts when they get hard and squeal instead of tightening the hell out of them and blowing all the accesory bearings. GD Just for future reference, do you have that part number? Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted May 24, 2011 Share Posted May 24, 2011 23700AA34ARA https://www.1stsubaruparts.com/partscat.html Copy and paste it into the search box to see their price. Quote Link to comment Share on other sites More sharing options...
sario Posted May 24, 2011 Author Share Posted May 24, 2011 23700AA34ARAhttps://www.1stsubaruparts.com/partscat.html Copy and paste it into the search box to see their price. Thanks. That's a great deal for a rebuilt OEM alternator. Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted May 24, 2011 Share Posted May 24, 2011 Apparently it was a pretty big problem. Every one of the cars of this era that I've ever looked under the hood of has a Subaru reman sticker on the alternator. Quote Link to comment Share on other sites More sharing options...
