Pooparu Posted May 23, 2011 Share Posted May 23, 2011 Can I fit a 1981 BRAT front cross member on the frame of a 1977 GL Coupe frame? I'm trying to update the drive train of my 1977 coupe to EA81 running gear. Quote Link to comment Share on other sites More sharing options...
Caboobaroo Posted June 2, 2011 Share Posted June 2, 2011 Don't see why not. Is the coupe a stage 2? It should bolt in AFAIK Quote Link to comment Share on other sites More sharing options...
Pooparu Posted June 4, 2011 Author Share Posted June 4, 2011 Don't see why not. Is the coupe a stage 2? It should bolt in AFAIK Stage 1 Quote Link to comment Share on other sites More sharing options...
Leeroy Posted June 4, 2011 Share Posted June 4, 2011 You should be able to do it... The late stage 1 has the steering gearbox sitting on top of the engine cross member, rather than underneath as in the early stage 1s. This would mean it is similar to the '81 cross member. Quote Link to comment Share on other sites More sharing options...
moosens Posted June 4, 2011 Share Posted June 4, 2011 I've always wanted to do what you're doing , Earl , but man can't you find a more of a beater example to do that to? Quote Link to comment Share on other sites More sharing options...
Caboobaroo Posted June 4, 2011 Share Posted June 4, 2011 I will pull my FSMs out later and see if they give dimensions. Quote Link to comment Share on other sites More sharing options...
Pooparu Posted June 4, 2011 Author Share Posted June 4, 2011 I've always wanted to do what you're doing , Earl , but man can't you find a more of a beater example to do that to? I know, I know... (you old school purest are so particular). I want to go with a complete EA81 drive train. I've got a guy in AUS. that's going to ship me some duel port heads & a duel carb set up for an EA81. So I want to build the crap out of the motor (EA71 pistons, H.P. cam grind...). I'm going to strip the body down to bear metal and straighten out all of the dings and patch in the few small rust areas. I just need to start collecting all of my parts then the build begins. Quote Link to comment Share on other sites More sharing options...
