ericem Posted May 27, 2011 Share Posted May 27, 2011 (edited) Hey guys just want some opinions I am going to tackle fixing my friends 2000 impreza rs he hit a curb at "unknown speeds" and right now looked like front control arm replacement possibly crossmember as well, rack, swap bar and endlink, struts all around ill be doing wheels. In the rear he hit the curb as well looked like it just needed a strut only. Now reason I am thinking he needs a new crossmember is because the motor is sitting like a 1cm sideways id say. I am either going to swap in a crossmember from a 92 legacy turbo or I am thinking possible the bushing for the crossmember have been damaged. I am curious what others have found in similar repairs. I will post some pics tomorrow. Edited May 27, 2011 by ericem Link to comment Share on other sites More sharing options...
Fairtax4me Posted May 27, 2011 Share Posted May 27, 2011 It may have just shifted the cross member or bent the bolts. If the bolts are bent you'll have a ton of fun getting them out. Link to comment Share on other sites More sharing options...
ericem Posted May 27, 2011 Author Share Posted May 27, 2011 yay lol ok so ill try loosening up the crossmember and see if it can get it to sit in the normal position otherwise I guess hes in for a crossmember. Link to comment Share on other sites More sharing options...
bheinen74 Posted May 28, 2011 Share Posted May 28, 2011 no, only the control arm will fail. It is the weakest link and is designed to bend to save everything else. It will have a bend in the middle of it, you could compare it to a known good control arm Taco'd control arm is the term. Link to comment Share on other sites More sharing options...
ericem Posted June 2, 2011 Author Share Posted June 2, 2011 so started working on it. Tried swapping the rear struts doesnt appear the strut is bent but possibly the hub. Anyone experience the hub being bent. Link to comment Share on other sites More sharing options...
ericem Posted June 2, 2011 Author Share Posted June 2, 2011 Guess no one experiences the hub being bent? The laterals and trailing arm show no signs of damage or bent just there is alot of positive camber even with a new strut its the same. It is hard to tell but it does appear the hub is bent I just wanted to hear someone else has experienced this or else I am thinking there is something else bent severely. Link to comment Share on other sites More sharing options...
Subie Gal Posted June 2, 2011 Share Posted June 2, 2011 I've bent a hub or 2 before. NO visible signs of damage, other than the camber was screwed, and the wheel/tire was rubbing on the strut. Swapped in a new hub - aligned - and all was well again. Note for the front damage Check the control arm and inner tie rod end. 99.999% of the time with side impacts, these 2 items are toasted. jamie Link to comment Share on other sites More sharing options...
Fairtax4me Posted June 2, 2011 Share Posted June 2, 2011 You talking about the rear knuckle? People have bent those pressing wheel bearings in and out. The hub itself (the part the wheel and rotor bolt to) gonna be some trick to bend that. Link to comment Share on other sites More sharing options...
Subie Gal Posted June 2, 2011 Share Posted June 2, 2011 most people when they state "hub" mean the housing assembly and not the actual wheel hub. I got what ya meant and that's what I referred to.... Link to comment Share on other sites More sharing options...
ericem Posted June 3, 2011 Author Share Posted June 3, 2011 ya sorry guys i guess i mean knuckle and yes the housing. I got a hub out of my old car took alot of hammering to get out the stupid abs sensor im hoping the one in his hub comes out fine. Link to comment Share on other sites More sharing options...
ericem Posted June 16, 2011 Author Share Posted June 16, 2011 Just a update the rear is all straightened up replaced the bent hub and installed new strut perfect! Now back to the front. Looks like the mount on the crossmember for the control arm is off by 1/2-1" . Also keep in mind the motor is actually sitting slightly sideways. The driveside of the engine is sitting slightly closer maybe 1/2" to the rad which makes no sense IMO. I am now wondering are the bolts bent or the crossmember itself? How do I remove the bolts or studs I mean for the xmember just so I can atleast check them to see if they are straight? Link to comment Share on other sites More sharing options...
subaruplatt Posted June 17, 2011 Share Posted June 17, 2011 so started working on it. Tried swapping the rear struts doesnt appear the strut is bent but possibly the hub. Anyone experience the hub being bent. My experience with a VW was that when I curbed the car I put a warp in the hub. The Consequence of this was that the warp would eventually radiate outwards and seed warpage of the rotors. I had several expensive brake jobs done before someone finally figured it out why. Also if hit hard enough wheel bearing might be pooched as well. Link to comment Share on other sites More sharing options...
ericem Posted June 17, 2011 Author Share Posted June 17, 2011 I think the curb actually hit the crossmember possibly which is why I am having this issue. Link to comment Share on other sites More sharing options...
ericem Posted July 2, 2011 Author Share Posted July 2, 2011 So replaced the crossmember control arm and everything lined up but it appears the knuckle is warped. I am wondering can I use a hub from a pre 99 which has the abs tone ring on the hub instead of the axle? Will they read the same voltage? Link to comment Share on other sites More sharing options...
