ea2ej swap: Starter clearance?
MilesFox
I have an ej22 from o1 impreza mated to an xt6 5mt, ea82 flywheel and pp. I am using the car's original starter from fwd 5spd.
I think i remember there is a slight clearance issue. I need to know how much spacing is needed, the best manner to do so, or if i should use a different starter.
It shounds like the bendix gear is dragging along when the engine is running. I have only run the engine long enough to start, and to test alternator oputput.
Isnt there a difference with the throw on an auto v.s manual starter? Say if you have an auto trans and a starter for a manual you could get the symptom you describe or if you have a auto starter on a manual car it could not fully engage the flywheel and eat teeth some times. :rolleyes:
I swapped the starter out wit the one that was original to the engine and adapter plate behind a 4spd ea81 trans.
Still had the starter dragging with the flywheel.
I put some washers between the trarter and the trans and that cured it. I used ea82 head bolt washers. I would have used thinner ones if i could find 2 that matched out of my 5 gallon buckets of subaru hardware.
I cannot explain why it was rubbing, but the variable was 4spd vs 5spd trans with this particualr adaptrer and flywheel(ea82)
