kxracer741 Posted May 28, 2011 Share Posted May 28, 2011 SO I have recently swapped a 2.2 into my 1998 legacy Outback. After the swap I replaced the knock sensor as it was throwing a code. Ran much better after that was replaced, however the Car cuts out very bad at 4,000 rpm, however it does not cut out in first gear and im able to rev it to the moon in first gear. Any ideas on what this problem could be? FWI it did this before the sensor was changed as well. Link to comment Share on other sites More sharing options...
kxracer741 Posted May 30, 2011 Author Share Posted May 30, 2011 any help Link to comment Share on other sites More sharing options...
987687 Posted May 30, 2011 Share Posted May 30, 2011 Does it feel like you're hitting the rev limiter? If the CEL is on, see what it is. Some codes will put it in limp mode. Link to comment Share on other sites More sharing options...
kxracer741 Posted May 31, 2011 Author Share Posted May 31, 2011 It does feel like it is hitting the rev limiter, however there is no CEL... Link to comment Share on other sites More sharing options...
MilesFox Posted May 31, 2011 Share Posted May 31, 2011 We had a similar symptom in an EJ brat, that the revs were limited to 4000 rpm until we hooked up the VSS signal wire. Link to comment Share on other sites More sharing options...
nipper Posted June 2, 2011 Share Posted June 2, 2011 Double check all your connections. You are in limp mode. Link to comment Share on other sites More sharing options...
kxracer741 Posted September 2, 2011 Author Share Posted September 2, 2011 UPDATE!!!! Im very determined to get this fixed as I Have trouble getting up steeper hills as it cuts out at 4000 rpm. The Im using the 2.5 intake manifold as well as throttle body/intake on the 2.2 motor. dont know if this makes a difference. So far this is what has been replaced- Fuel Filter ECU (replaced the 2.5 ecu with a 2.2 ecu) Knock Sensor any other ideas? Could it be the VSS wire? Again there is no CEL Please help!! Link to comment Share on other sites More sharing options...
nipper Posted September 2, 2011 Share Posted September 2, 2011 You are in limp mide, not many things do that. A vss signal can do this but if you have a spedo ... *ahem* It should be fine. is it just hitting a ceiling or breaking up at 4K Link to comment Share on other sites More sharing options...
987687 Posted September 2, 2011 Share Posted September 2, 2011 A 2.5 intake manifold won't physically bolt to 2.2 heads. Have you swapped heads? You don't need to swap computers, I'd try going back to the stock one to see if thats the problem. Link to comment Share on other sites More sharing options...
kxracer741 Posted September 2, 2011 Author Share Posted September 2, 2011 I ran the stock one for 6 months and just swapped out the ecu today cuz i got a smokin deal on one. anyway it breaks up at 4,000 but will keep reving than clears up at 4500. I dont undertand what u mean by the speedo and the VSS? please explain Link to comment Share on other sites More sharing options...
nipper Posted September 2, 2011 Share Posted September 2, 2011 Does the spedometer work ? Link to comment Share on other sites More sharing options...
kxracer741 Posted September 2, 2011 Author Share Posted September 2, 2011 yeah works perfect Link to comment Share on other sites More sharing options...
987687 Posted September 2, 2011 Share Posted September 2, 2011 yeah works perfect Do you have a check engine light? Specifically code p0500? That's the vss code, it will put the computer into limp mode. As will many other codes. Link to comment Share on other sites More sharing options...
nipper Posted September 2, 2011 Share Posted September 2, 2011 If it was breaking up it would have been an engine related issue, but since it just stops responding it is a limp mode of some kind. Go back and check ALL your harnesses for damage and dsiconnect and reconnect everything. Lets start with the basics. Link to comment Share on other sites More sharing options...
CNY_Dave Posted September 2, 2011 Share Posted September 2, 2011 There's a possibility of a cam or crank position sensor/reluctor type mismatch, maybe? I've seen that cause a no-spark, but not a poor running condition. Dave Link to comment Share on other sites More sharing options...
kxracer741 Posted September 2, 2011 Author Share Posted September 2, 2011 It cleans up around 4500 rpm after stuttering at 4000 rpm. I think I'm going to do plugs and plug wires? Should I do them? Link to comment Share on other sites More sharing options...
987687 Posted September 2, 2011 Share Posted September 2, 2011 It cleans up around 4500 rpm after stuttering at 4000 rpm. I think I'm going to do plugs and plug wires? Should I do them? If they aren't NGK plugs and subaru or NGK wires, yes, do them. Link to comment Share on other sites More sharing options...
kxracer741 Posted September 2, 2011 Author Share Posted September 2, 2011 so could that be my problem? Link to comment Share on other sites More sharing options...
Olnick Posted September 2, 2011 Share Posted September 2, 2011 so could that be my problem? No way to know 'til you try it. But generally Subarus run much better with the proper new plugs & wires. If they haven't been changed in a long time it's a good investment. Hope it solves your problem. Link to comment Share on other sites More sharing options...
987687 Posted September 2, 2011 Share Posted September 2, 2011 Before I***knew better, I used bosch plugs. This was the result.... These were in for about two weeks, never ran right, and just got worse. The wires were crap from pep boys. I finally started pulling stuff when it didn't run when wet. Spark show under the hood.... Switched to good parts and it fine again. Here's the plug Link to comment Share on other sites More sharing options...
kxracer741 Posted September 3, 2011 Author Share Posted September 3, 2011 i bought belden premium spark plug wires and ngk plugs, gonna be installing them tonight. I dont know what is next after i install these Link to comment Share on other sites More sharing options...
nipper Posted September 3, 2011 Share Posted September 3, 2011 Just a question, how is the timing belt? Link to comment Share on other sites More sharing options...
kxracer741 Posted September 3, 2011 Author Share Posted September 3, 2011 good question, i dont know. im thinking it may be a timing issue. how would i check that? Link to comment Share on other sites More sharing options...
nipper Posted September 3, 2011 Share Posted September 3, 2011 General rule is when you swap a subaru engine, the timing belt, idlers, seals and water pump should all be done as they are much easier out of the car, especialy on an unknown engine. Link to comment Share on other sites More sharing options...
nipper Posted September 3, 2011 Share Posted September 3, 2011 It may not be the issue but it needs to be done along with a full tuneup. Link to comment Share on other sites More sharing options...
