the sucker king Posted May 31, 2011 Share Posted May 31, 2011 like the title says. i can't find on ebay or from subaru. Anyone have part numbers? the resistor I am refering to is the little plug in on the bottom of the heater (vent) box. By the way how does the resistor work? Link to comment Share on other sites More sharing options...
the sucker king Posted June 1, 2011 Author Share Posted June 1, 2011 got these ordered from a dealership today. It seems like whenever you get parts for a 30 year old subaru you get the "two units left in the whole country" line. So can anyone explane how that resistor works? I don't get it. Link to comment Share on other sites More sharing options...
essexkun Posted June 1, 2011 Share Posted June 1, 2011 Resistors limit the flow of electricity. There is a resister per fan setting (from from low to just before high), each setting allows more power to the fan to increase speed until you turn it to high, which bypasses the resistors and delivers full current to the fan. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted June 1, 2011 Share Posted June 1, 2011 got these ordered from a dealership today. It seems like whenever you get parts for a 30 year old subaru you get the "two units left in the whole country" line. That's because SOA only orders half a dozen units at a time from Japan and only when the current stock is entirely depleted. We have seen this with EA81 oil pumps for example. Sometimes have to wait a couple weeks for the stock to be refilled from Japan. When no more of the valves are left in the country they will order 6 of them from Japan and they will be out of stock till more arrive. GD Link to comment Share on other sites More sharing options...
the sucker king Posted June 2, 2011 Author Share Posted June 2, 2011 Resistors limit the flow of electricity. There is a resister per fan setting (from from low to just before high), each setting allows more power to the fan to increase speed until you turn it to high, which bypasses the resistors and delivers full current to the fan. Right but what I don'y get is why this resister is mounted on near the bottom of the vent box inside the box itself. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted June 2, 2011 Share Posted June 2, 2011 Right but what I don'y get is why this resister is mounted on near the bottom of the vent box inside the box itself. Because the resistor is made from coils of nichrome wire and without the cooling effect of the airflow from the vent duct it would rapidly overheat and fail. GD Link to comment Share on other sites More sharing options...
the sucker king Posted June 3, 2011 Author Share Posted June 3, 2011 Because the resistor is made from coils of nichrome wire and without the cooling effect of the airflow from the vent duct it would rapidly overheat and fail. GD Well see, I knew there was a reason. Thanks. Link to comment Share on other sites More sharing options...
