e2thewags Posted June 1, 2011 Share Posted June 1, 2011 What is the black film in the coolant res.??? Link to comment Share on other sites More sharing options...
idosubaru Posted June 1, 2011 Share Posted June 1, 2011 probably just dirt/contamination. after 10+ years stuff starts to accumulate. failing headgaskets can make the overflow dirty as well, but that's less likely on the version EJ25 in that car. Link to comment Share on other sites More sharing options...
nipper Posted June 2, 2011 Share Posted June 2, 2011 Slime. Take out the tank (if possible I don't remeber how they come out in 2000). I put small pebbels in the tank and shake the hell out of it with some water in the tank. Others may have other methods, which leads to the next question .... when was the last time the coolant was changed? Link to comment Share on other sites More sharing options...
e2thewags Posted June 2, 2011 Author Share Posted June 2, 2011 It got changed before the trip from MN to TX where along the way the #2 timing idler sprocket failed and the thing shut down.. Link to comment Share on other sites More sharing options...
e2thewags Posted June 2, 2011 Author Share Posted June 2, 2011 Im worried about valve damage.. its been sitting for 2 yrs finally got time to mess with it, all new fluids gaskets and o-rings.. got it down to replacing the timing pulleys, then a compression test... Link to comment Share on other sites More sharing options...
davebugs Posted June 2, 2011 Share Posted June 2, 2011 I use a local degreaser (Buster) and gravel (because they are mixed sizes) I scoop up in the driveway. A trick I learned years ago when doing a gas tank coating kit on an old VW beetle. Remember when shalking there is a small hole that'll leak and it always seems tough to keep a finger covering it and still sake vigorousely(sp?). Someone I mentioned this to years ago was an apartment dweller and bought aquarium gravel and said that worked. This reminds me to list some of these on Ebay. I try and keep 2 clean ones ahead. Can't belive folks do HG jobs and leave the crappy overflow bottles looking so bad. Link to comment Share on other sites More sharing options...
e2thewags Posted June 2, 2011 Author Share Posted June 2, 2011 I ended up putting some Dawn in it , yeah dont do that it work ok but I had to rinse it like 50 times...it doesnt have to be pretty though this thing hasnt ran in almost 3 yrs...hopefully in a few days:banana: Link to comment Share on other sites More sharing options...
