Suba_GL_87 Posted June 6, 2011 Share Posted June 6, 2011 i have a good boat 13' with 15hp but i dont know how much weight my boat. look like under a ton. im wonder what kind for good hitch bar on my 87' suba wagon EA82? so, i can buy for new hitch bar. Link to comment Share on other sites More sharing options...
Turbone Posted June 7, 2011 Share Posted June 7, 2011 You really wont know what to get if you dont know the weight of the boat. and trailer. Its called tongue weight and it determines what size hitch you need. Link to comment Share on other sites More sharing options...
Suba_GL_87 Posted June 7, 2011 Author Share Posted June 7, 2011 1 7/8 ball Turbone said: You really wont know what to get if you dont know the weight of the boat. and trailer. Its called tongue weight and it determines what size hitch you need. Link to comment Share on other sites More sharing options...
nipper Posted June 7, 2011 Share Posted June 7, 2011 Tounge weight is easy, use a bathroom scale and for a boat it should read on a scale. The boat should have a weight tag hopefully someplace or ask a boatyard, same for the trailer. Link to comment Share on other sites More sharing options...
Suba_GL_87 Posted June 7, 2011 Author Share Posted June 7, 2011 alright. but i dont have any hitch bar...i need to know what kind hitch model for my wagon gl 87' nipper said: Tounge weight is easy, use a bathroom scale and for a boat it should read on a scale. The boat should have a weight tag hopefully someplace or ask a boatyard, same for the trailer. Link to comment Share on other sites More sharing options...
Redcap Posted June 7, 2011 Share Posted June 7, 2011 Suba_GL_87 said: alright.but i dont have any hitch bar...i need to know what kind hitch model for my wagon gl 87' And that depends entirely on how much tongue weight you need to run. Link to comment Share on other sites More sharing options...
nipper Posted June 7, 2011 Share Posted June 7, 2011 Is there even a hitch available for the car? Link to comment Share on other sites More sharing options...
Suba_GL_87 Posted June 7, 2011 Author Share Posted June 7, 2011 well, my boat look like under 2,000LB. Redcap said: And that depends entirely on how much tongue weight you need to run. Link to comment Share on other sites More sharing options...
Suba_GL_87 Posted June 7, 2011 Author Share Posted June 7, 2011 which one kind hitch bar for on my subaru wagon gl on it? boat like a under 2,000lb... nipper said: Is there even a for hitch available for the car? Link to comment Share on other sites More sharing options...
bigjimd Posted June 7, 2011 Share Posted June 7, 2011 I would run this if it were me buying it. http://www.uhaul.com/MovingSupplies/Hitches.aspx Link to comment Share on other sites More sharing options...
MilesFox Posted June 7, 2011 Share Posted June 7, 2011 good luck as u-haul is going to have a near impossible to find 250 dollar hitch for some bumper piece, class 2 at best, compared to buying ford f350 itches all day for 100 bucks and class 3 rating. i modified my car to accept a ford f250 hitch. If you cant get it from u-haul, it wont exist, since uhaul carries curt, valley, and other top makes(no reese), and their part numbers are the same as the manufacturer number which is the same number that any other store would have. but, whatever you can find, will work just fine! Link to comment Share on other sites More sharing options...
Mr. Brat Posted June 7, 2011 Share Posted June 7, 2011 Quote which one kind hitch bar for on my subaru wagon gl on it? boat like a under 2,000lb... This is not answering the question... You are saying that you THINK it weighs that much... That is NOT the tounge weight. You are refering the the GVW (gross vehile weight) which is the second part of figuring what hitch you need. You NEED to know your tounge weight to determine what class of hitch you need... If you dont know how to do that (just read above, Nipper told you how to do this) then just get a class 3 hitch with a 2 inch reciever. You could just take it to a hitch shop and they can tell you what you need. Link to comment Share on other sites More sharing options...
987687 Posted June 7, 2011 Share Posted June 7, 2011 Just a cautionary. I really wouldn't try to tow over 1000 LBS. I have a custom tow bumper I made up for my GL and have towed some stupid heavy things. Turning and braking is hairy. And I have 4wheel disc brakes on my car. Link to comment Share on other sites More sharing options...
El Presidente Posted June 7, 2011 Share Posted June 7, 2011 (edited) 987687 said: Just a cautionary. I really wouldn't try to tow over 1000 LBS. I have a custom tow bumper I made up for my GL and have towed some stupid heavy things.Turning and braking is hairy. And I have 4wheel disc brakes on my car. X2... Can a GL tow 4,000lb ? Yes, I've seen it Could a Gl manuever a 4,000 trailer at highway speeds? Absolutely NO No one has mention Gross Trailer Weight Rating! It much more important the the tongue weight! The heavier the trailer AND cargo, the more its going to kick you around when driving and I have seen a RV pull a fullsize truck right off the freeway and into the grass, just because the RV hit a pot hole and started to sway. If theres still a tag on your boat(it came with one) its usually on the transom next to where the motor mounts or in the pilot house if you have one. If its not there, have a buddy tow your boat over a truck scale. I've only used ones around me that are closed, but just pull on the pad, and look through the window. You willn't get in trouble, your tax dollars paid for it. Edited June 7, 2011 by El Presidente Link to comment Share on other sites More sharing options...
987687 Posted June 7, 2011 Share Posted June 7, 2011 Is it an aluminum boat? If it is, that plus a 15hp engine probably don't weigh more than 350 lbs. How much does your trailer weigh? If it's just a small one-axle boat trailer probably not much. If it isn't a home made trailer (like mine...) it should have a sticker on it with specs/ratings. Link to comment Share on other sites More sharing options...
nipper Posted June 7, 2011 Share Posted June 7, 2011 how much is the car rated to tow Link to comment Share on other sites More sharing options...
987687 Posted June 7, 2011 Share Posted June 7, 2011 I'm curious about that too... Anyone with a user manual? My car didn't come with one... Link to comment Share on other sites More sharing options...
92_rugby_subie Posted June 7, 2011 Share Posted June 7, 2011 http://www.ultimatesubaru.org/forum/showthread.php?t=83596&highlight=towing+capacity this might help. Link to comment Share on other sites More sharing options...
92_rugby_subie Posted June 7, 2011 Share Posted June 7, 2011 ^ might give you a few good laughs too haha Link to comment Share on other sites More sharing options...
nipper Posted June 7, 2011 Share Posted June 7, 2011 Just because someone has seen someone else tow a heavy trailer with a smaller car doesnt mean it hasnt started off with "Here hold my beer ...." Link to comment Share on other sites More sharing options...
MilesFox Posted June 7, 2011 Share Posted June 7, 2011 Mr. Brat said: This is not answering the question... You are saying that you THINK it weighs that much... That is NOT the tounge weight. You are refering the the GVW (gross vehile weight) which is the second part of figuring what hitch you need. You NEED to know your tounge weight to determine what class of hitch you need... If you dont know how to do that (just read above, Nipper told you how to do this) then just get a class 3 hitch with a 2 inch reciever. You could just take it to a hitch shop and they can tell you what you need. Typically tongue weight is 10% of the overall load, so that would be 200 pounds on a 2000 lb load Link to comment Share on other sites More sharing options...
MilesFox Posted June 7, 2011 Share Posted June 7, 2011 If you do look in a factory owners book, it will stat that "Towing with your subaru is not recommended" In my opinion, i think the driveline of a subaru with its engine would haul a 1 ton load on its back, or pull 5,000 lbs, if the subaru itself were heaveier, with heavy enough hubs and bearings to support the weight. I have towed whole cars with GL subarus, once across 300 miles through chicago. I would say if you are towing with a subaru, its not as relavant as what the car can do and the weight of the trailer, but the experience of the person driving, and understanding the dynamics of towing. Towing a fishing boat with a subaru is cake. end of story. Link to comment Share on other sites More sharing options...
987687 Posted June 7, 2011 Share Posted June 7, 2011 Just because it can be done, doesn't mean it's a good idea ... But ya, having a clue about towing does help. Things like not slamming on the brakes on a corner... etc will probably help keep you alive towing a heavy load with a small car. Link to comment Share on other sites More sharing options...
Ricearu Posted June 7, 2011 Share Posted June 7, 2011 double Link to comment Share on other sites More sharing options...
Ricearu Posted June 7, 2011 Share Posted June 7, 2011 towed an aluminum john boat with johnson 9.9 on it with a GL. I could lift the trailer tongue single handed. there was no jack, only a kick stand on the tongue. I probobly wouldn't tow a fiberglass heavy boat. Link to comment Share on other sites More sharing options...
