subaru420 Posted March 8, 2004 Share Posted March 8, 2004 I got the new EA81 in and it will turn and sometimes sound like its gonna start but more often it will cough through the tube that run from the sides of the engine to the carb/airbox. It keeps spitting back up through the carb and kicking out a puff of blueish smoke through the carb. Any ideas? I need help ASAP Link to comment Share on other sites More sharing options...
calebz Posted March 9, 2004 Share Posted March 9, 2004 Backfiring through the carb.. I would start by checking, and rechecking the timing. Link to comment Share on other sites More sharing options...
GLCraig Posted March 9, 2004 Share Posted March 9, 2004 You Might have your Distributor 180degs out Link to comment Share on other sites More sharing options...
TomRhere Posted March 9, 2004 Share Posted March 9, 2004 Sounds like ignition timing to m, too. Link to comment Share on other sites More sharing options...
Nug Posted March 9, 2004 Share Posted March 9, 2004 Yep Check your firing order...again. Link to comment Share on other sites More sharing options...
subaru420 Posted March 9, 2004 Author Share Posted March 9, 2004 My chilton manual was 100% wrong on what was the #1 cylender. I called my super subaru repair guy and corrected me on that. I made tha change and it started right up. Only thing left to do now is get my SUPER LOUD EXHAUST fixed. Anyone know of a good exhaust place in the seattle area???? Link to comment Share on other sites More sharing options...
Nug Posted March 9, 2004 Share Posted March 9, 2004 Good to hear it's running. Chilton's manuals suck. Link to comment Share on other sites More sharing options...
NoahDL88 Posted March 9, 2004 Share Posted March 9, 2004 I have that same problem, but when turing it over, and checking with a timing light it says its right on, could it still be 180 out? Link to comment Share on other sites More sharing options...
subaru420 Posted March 9, 2004 Author Share Posted March 9, 2004 Noah, Be carefull when you are doing this... that backfiring actually lit my airfilter on fire. Good thing I had a hose handy What I did was pulled the passenger side front plug, stuck my finger over the plug hole, then with a wrench turned the engine untill I felt air pressure escaping past my finger. That should be TDC (or close to it). Then lift your distributor up a little so the teath aren't engaging the engines gears anymore. Then take the cap off and turn the rotor untill it is over the plug that has the wire running to that cylender. Slide the distributor back down, replace your plug and wire... then if you have the same luck as me it will fire up. You should be close enough there to be able to time it after that. Good luck! Link to comment Share on other sites More sharing options...
hatch4x4 Posted March 10, 2004 Share Posted March 10, 2004 Even with timing right, you can still be 180 out. Link to comment Share on other sites More sharing options...
NoahDL88 Posted March 10, 2004 Share Posted March 10, 2004 Thats what i wanted to hear, i think that last time i tried this build i had it out 180, or had the wires swaped, 3,4 backwards so it only fired on 1,2 so i'm thinking that my timing may be off by 180, but i can't try to test it until sunday when i get back to michigan. Link to comment Share on other sites More sharing options...
MilesFox Posted March 10, 2004 Share Posted March 10, 2004 the #1 cylinder is on the passenger side front. the distributor turns counter clockwise. firing order is 1324. there is a rubber plug on the bellhousing that can be removed to access the timing marks on the flywheel. line up the rotor to #1 cyl. the timing should be 8 deg. btdc Link to comment Share on other sites More sharing options...
