Scott in Bellingham Posted June 9, 2011 Share Posted June 9, 2011 wondering if anyones seen a Subaru engine mated to a Jeep tranny and transfercase like a 90s trans ?? Link to comment Share on other sites More sharing options...
bill hincher Posted June 9, 2011 Share Posted June 9, 2011 that should be the A-15 ? from asian ? its the same as the R 150 front housing, but I beleve the input shaft is much longer, a spacer plate would have to be built to allow the use of the current bellhousing to accept it, but it can be done Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted June 9, 2011 Author Share Posted June 9, 2011 that should be the A-15 ? from asian ? its the same as the R 150 front housing, but I beleve the input shaft is much longer, a spacer plate would have to be built to allow the use of the current bellhousing to accept it, but it can be done so a spacer may do it? I could do that , starter seems may be a issue Link to comment Share on other sites More sharing options...
bill hincher Posted June 9, 2011 Share Posted June 9, 2011 so a spacer may do it? I could do that , starter seems may be a issue no man, Its a direct bolt up, the only difference between the A 15 and R 150, 151, 154 is the input shaft length they all share the exact same bolt pattern, thats why I included the bolt pattern on the original bellhousing, now all thats required is a spacer, or a new housing could be cast from the original pattern to include the length Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted June 9, 2011 Author Share Posted June 9, 2011 no man, Its a direct bolt up, the only difference between the A 15 and R 150, 151, 154 is the input shaft length they all share the exact same bolt pattern, thats why I included the bolt pattern on the original bellhousing, now all thats required is a spacer, or a new housing could be cast from the original pattern to include the length so your toyota adapter will work on a jeep Link to comment Share on other sites More sharing options...
bill hincher Posted June 9, 2011 Share Posted June 9, 2011 yes, it will bolt up but you are responsible to find the throw bearing and clutch disc Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted June 9, 2011 Author Share Posted June 9, 2011 yes, it will bolt up but you are responsible to find the throw bearing and clutch disc how much for the bellhousing to adapt a EJ22 to a 95 Jeep Grand cherokee manual tranny ? Link to comment Share on other sites More sharing options...
bill hincher Posted June 9, 2011 Share Posted June 9, 2011 its not that easy there is a lot of attention to detail to design a functional bellhousing to a given transmission/engine combination pilot bearings, throw out bearings, throw out bearing holders, custom disc's everything has to work together If you want to invest your time, I would be glad to help you Link to comment Share on other sites More sharing options...
86hatchback Posted June 13, 2011 Share Posted June 13, 2011 I'm pretty sure the gear trains are interchangeable with those transmissions. You can use a Toyota g52 gears on the jeep ax5 main shaft. I know for sure the fifth gears swap I'm pretty sure the gears will fit the main shaft as well. I would assume that the ax15 and R series transmissions are the same way. Link to comment Share on other sites More sharing options...
bill hincher Posted June 13, 2011 Share Posted June 13, 2011 yeah, for all the trouble its better just to stay with the Toyota trans, but each to his own, the versitility is built into the housing Link to comment Share on other sites More sharing options...
