1-3-2-4 Posted June 20, 2011 Share Posted June 20, 2011 Not sure if anyone else has had this issue but I notice from right turns only with the turn signal on and I let the wheel return to center on it's own my turn signal instead of stop flashing it will switch over to the left turn signal. At first I thought it was just me... I'm going to guess it's something with the roll connector? It's no big deal it just gets annoying because you never know when it might happen. Link to comment Share on other sites More sharing options...
Suzam Posted June 21, 2011 Share Posted June 21, 2011 I've got a 97 Legacy L Wagon that will sometimes turn the left signal OFF as I turn the wheel into the turn. So if I'm waiting to turn left it's fine but as I start to turn at the point where it would bump it on the way back it bumps it the way out. It's hit or miss and I have already signaled so it's not that big of a problem. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted June 21, 2011 Author Share Posted June 21, 2011 yeah it's odd I don't understand it. Link to comment Share on other sites More sharing options...
Fairtax4me Posted June 21, 2011 Share Posted June 21, 2011 I've seen this happen on a few cars. I figure it's just a worn detent spring in the signal switch, but I've never had one apart to find out. Link to comment Share on other sites More sharing options...
987687 Posted June 22, 2011 Share Posted June 22, 2011 There's a ball with a spring. The ball bearing is forced up over a little hill into a valley when you turn it right or left. In the center the ball bearing is in a bigger valley. Over time the hills between the top valleys sort of erode. And the reason it falls into left is because gravity is already pulling the stick downwards, so since it's going down anyway having just come from turning right it keeps on going... I hope that sort of makes sense. Link to comment Share on other sites More sharing options...
nipper Posted June 23, 2011 Share Posted June 23, 2011 I have this. The cam is worn, and at almost 300,000 miles it is allowed. I am not really going to dig into the steering wheel to fix it unless it gets worse. Link to comment Share on other sites More sharing options...
Suzam Posted June 24, 2011 Share Posted June 24, 2011 There's a ball with a spring. The ball bearing is forced up over a little hill into a valley when you turn it right or left. In the center the ball bearing is in a bigger valley. Over time the hills between the top valleys sort of erode. And the reason it falls into left is because gravity is already pulling the stick downwards, so since it's going down anyway having just come from turning right it keeps on going... I hope that sort of makes sense. It kind of makes sense, but it sounds more like when when I was a 16 year old sophomore and on a date with one of the senior cheerleaders! Link to comment Share on other sites More sharing options...
1-3-2-4 Posted June 24, 2011 Author Share Posted June 24, 2011 it's just annoying.. I guess this person did lots of left turns and always used the turn signal unlike BMW owners Link to comment Share on other sites More sharing options...
987687 Posted June 24, 2011 Share Posted June 24, 2011 unlike BMW owners Link to comment Share on other sites More sharing options...
1-3-2-4 Posted June 24, 2011 Author Share Posted June 24, 2011 Hah it's true I bet if someone did the statistics on that stuff they would see! Link to comment Share on other sites More sharing options...
