bluebonnet81 Posted June 21, 2011 Share Posted June 21, 2011 I just bought this sweet car a few days ago and it has an issue im having a hard time putting my finger on. It only has 65,000 miles on it and I got it for a thousand bucks =D It is an 81 gl 1.8 2WD auto Idle is ok. When I give gas in park or neutral, everything is good. When I put it in gear and accelerate, I must do with a very soft touch until about 1600-1800 rpm where it picks up strong otherwise it wants to stall under a load. From a stop pointed uphill, dont even think about it. Fuel pump and fuel filter have been replaced with new, and I have sprayed carb cleaner in the carb several times. It has fresh gas , and I have put about 500 miles on it already. Please help ! Link to comment Share on other sites More sharing options...
Subarule Posted June 21, 2011 Share Posted June 21, 2011 That sounds pretty normal for the set-up you have. Just be sure you don't have any vacuum leaks. Link to comment Share on other sites More sharing options...
bluebonnet81 Posted June 21, 2011 Author Share Posted June 21, 2011 I thought that might be the case. Thanks for the advise! So to improve 1st gear acceleration would I have to replace Hitachi carb ? Link to comment Share on other sites More sharing options...
heartless Posted June 21, 2011 Share Posted June 21, 2011 #1 - check for vacuum leaks as already mentioned. With vehicle running spray carb cleaner or similar around the vacuum lines to see if there is any change in idle. with any type of carb - if the vehicle has been sitting for any length of time, it is possible it may have plugged up fuel passages, causing symptoms like you are describing - in more extreme cases, the engine will fire with a shot of starting fluid, but not be able to continue running on its own, because fuel flow is being restricted in any number of passages. Basic carb function info: http://en.wikipedia.org/wiki/Carburetor good luck. Link to comment Share on other sites More sharing options...
ferox Posted June 21, 2011 Share Posted June 21, 2011 So to improve 1st gear acceleration would I have to replace Hitachi carb ?Not necessarily. Being in Socal, replacing the fuel delivery system legally is a chore. For $10-$15 you can probably replace every vacuum hose in the engine bay, just do it one at a time. Run some Seafoam through the fuel system. Check your ignition timing. Not sure of your mechanical skill, but if you want to keep your car running in California you are going to need to learn it backwards and forwards. Oh and we like pictures. An '81 with 65,000 mi. must be witnessed Link to comment Share on other sites More sharing options...
bluebonnet81 Posted June 21, 2011 Author Share Posted June 21, 2011 [/img] Great ! All the vacuum hoses seem to be intact. I cut off some split ends, but it is still the same. I will try the sea foam, and follow up after that. Here are a couple photos. Enjoy! Link to comment Share on other sites More sharing options...
bluebonnet81 Posted June 21, 2011 Author Share Posted June 21, 2011 Link to comment Share on other sites More sharing options...
heartless Posted June 21, 2011 Share Posted June 21, 2011 very nice little wagon. um, yeah, cutting split ends off?? you need to completely replace those vacuum hoses, if the ends were splitting they are done. betting it will make a big difference once you do. Link to comment Share on other sites More sharing options...
Dirk Posted June 21, 2011 Share Posted June 21, 2011 +1 on checking the timing. Also could be the accelerator pump on the carb and/or a clogged idle jet. No amount of carb cleaner is going to help you if the jets are clogged. I would suggest removing and cleaning the jets. You need to remove the top of the carb for this. Be sure to take care not to damage the gasket when you do this. A carb re-build kit would be handy but in my opinion not essential at this stage. My recomendation would be to service and tune the engine as best as possible (getting to know the animal) before upgrading or modifying. cheers Dirk. Link to comment Share on other sites More sharing options...
Subarule Posted June 22, 2011 Share Posted June 22, 2011 My advice: start with the least expensive fix first (if indeed this fixes it) - replace all the vacuum hoses. They get brittle and then crack if the car sits for a long spell. Or they get soft and then ballon out when the car is up & running again, making weak spots (like arteries) Another piece of advice: run Marvel Mystery Oil through the gas tank at all times. I add some every time I fill the tank. Link to comment Share on other sites More sharing options...
Dannoo93 Posted June 22, 2011 Share Posted June 22, 2011 check your disty and the whole disty piece that goes into the engine Link to comment Share on other sites More sharing options...
bluebonnet81 Posted May 20, 2012 Author Share Posted May 20, 2012 (edited) It appears that a carb rebuild and plugs & wires fixed the problem. The carb was clean inside, but it was leaking air, and the carb tuning was all out of whack. Thanks for all the advise! Edited May 20, 2012 by bluebonnet81 Link to comment Share on other sites More sharing options...
Dirk Posted May 21, 2012 Share Posted May 21, 2012 Nice one mate! Link to comment Share on other sites More sharing options...
