JazzBass Posted June 21, 2011 Share Posted June 21, 2011 Hi all, I took a look underneath the car and found I have no return spring, so I think that's the source of (at least some) of the shifter wobble I have. I have a '95 (not sure on build month), but I have two part numbers for the spring and info I found. 33022GA081 (probably 4/95 - 7/96) 35044AA000 (probably 1/94 - 7/95) Can anyone point me to the correct part number or are they somewhat interchangeable? Also, in looking at where I think the spring goes, the two loops that the spring attaches to are not exactly straight across from each other. It's more of a diagonal. It's different from the pic or two that I've seen. Like this one.Do I have an issue? Thanks much folks! JB Link to comment Share on other sites More sharing options...
Fairtax4me Posted June 21, 2011 Share Posted June 21, 2011 The spring should go pretty much straight across. The retainer washer might be on backwards. I don't know of differences in the springs but there were differences in the linkage between several years. The springs may be slightly different length to accommodate that. Your build date should be on the sticker on the drivers door. Link to comment Share on other sites More sharing options...
JazzBass Posted June 21, 2011 Author Share Posted June 21, 2011 Fairtax4me, Thanks very much! Is the retainer washer something that I can replace relatively easily or does this require a more thorough procedure? Looks like, at least for mine, it's the 33022GA081 part number. I'll be getting it tomorrow. Thanks! JB Link to comment Share on other sites More sharing options...
Fairtax4me Posted June 21, 2011 Share Posted June 21, 2011 Nope , its the large washer with the hook for the spring. It has a flat cut into the hole in the middle so it only goes on one way. Just reach up in there with a 12mm wrench and take the nut off. I find it easier to install the spring with the washer removed. Just hook it to the washer, hold it with a finger while you fish it onto the shift linkage, then use the washer to pull back and expand the spring, and pop the washer back on the stud. With the shifter in 1st gear it's really easy. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted June 21, 2011 Share Posted June 21, 2011 Easy... if your dealer does not stock the washer be ready to wait as they ship it from SIA... Link to comment Share on other sites More sharing options...
JazzBass Posted June 22, 2011 Author Share Posted June 22, 2011 (edited) Thanks 1-3-2-4 and Fairtax4me, Well, I really don't know at this point. I took some pics for show and hopefully they will help. These were taken from behind the front driver side wheel. (Have no idea where the oil is coming from... Need to track that down) :-\ Full Album is Here What do you make of this? Thanks, JB Edited June 22, 2011 by JazzBass Link to comment Share on other sites More sharing options...
hankosolder2 Posted June 22, 2011 Share Posted June 22, 2011 Bear in mind that if you have any when the car is in gear, the spring will not help with that. It's only to "bias" the shifter to go into the 3-4 gate when the car is in neutral. It IS easier to find 3rd with a working spring, though. Good luck. Nathan Link to comment Share on other sites More sharing options...
1-3-2-4 Posted June 22, 2011 Share Posted June 22, 2011 I used to always miss 3rd when shifting from 2 to 3 without the spring Link to comment Share on other sites More sharing options...
Fairtax4me Posted June 22, 2011 Share Posted June 22, 2011 OK, the washer is on the right way so you don't have to worry about that. It looks like the trans was in gear for these pics? Which would explain why the holes seem to be diagonal to each other. Got a junkyard nearby? Probably find a spring real cheap at a U-pull-it place. Link to comment Share on other sites More sharing options...
JazzBass Posted June 22, 2011 Author Share Posted June 22, 2011 OK, the washer is on the right way so you don't have to worry about that. It looks like the trans was in gear for these pics? Which would explain why the holes seem to be diagonal to each other. Got a junkyard nearby? Probably find a spring real cheap at a U-pull-it place. Thanks guys! I'm actually doing ok finding third, believe it or not. I do have slop in gear, but other posts I have read said it would help with that. Oh well, either way, I'd like to get this fixed and working how it should. Yeah, the transmission was in gear. For spring installation it should be in neutral, I'm assuming? If so, I'm glad as I was really wondering what sort of a mess I have on my hands. Thanks very much! JB Link to comment Share on other sites More sharing options...
1-3-2-4 Posted June 22, 2011 Share Posted June 22, 2011 It's not going to help that much with slop in gear.. you need a new shifter knuckle it's the one with the 2 roll pins in it.. about a $60 part if I recall.. Link to comment Share on other sites More sharing options...
JazzBass Posted June 22, 2011 Author Share Posted June 22, 2011 It's not going to help that much with slop in gear.. you need a new shifter knuckle it's the one with the 2 roll pins in it.. about a $60 part if I recall.. It would figure. That's not bad on parts, just not looking forward to installing it. May need to have someone else do it. I appreciate it! JB Link to comment Share on other sites More sharing options...
1-3-2-4 Posted June 22, 2011 Share Posted June 22, 2011 It would figure. That's not bad on parts, just not looking forward to installing it. May need to have someone else do it. I appreciate it! JB It's doable.. it's better for space if you have the shifter in 5th gear.. I know I thought it was impossible too.. Lucky for me I will be getting a new transmission in July so I can have everything on the ground to look at. Link to comment Share on other sites More sharing options...
JazzBass Posted June 22, 2011 Author Share Posted June 22, 2011 It's doable.. it's better for space if you have the shifter in 5th gear.. I know I thought it was impossible too.. Lucky for me I will be getting a new transmission in July so I can have everything on the ground to look at. Cool deal about the transmission. Nice! Well, I may wind up giving it a shot myself. The dealer has the assembly for $65 or so. I got my spring so I'll try and put that in soon and deal with the knuckle assembly in the near future. So to install the spring, it's best to leave it in neutral? Thanks JB Link to comment Share on other sites More sharing options...
1-3-2-4 Posted June 22, 2011 Share Posted June 22, 2011 No because you wont have room put the car in 5th. and it's best to hook the spring on the far side then hook it on the washer. took me like 5 times before i got it to hook... it's a pretty stiff spring so if it pops off make sure you can find it! Link to comment Share on other sites More sharing options...
JazzBass Posted June 22, 2011 Author Share Posted June 22, 2011 No because you wont have room put the car in 5th. and it's best to hook the spring on the far side then hook it on the washer. took me like 5 times before i got it to hook... it's a pretty stiff spring so if it pops off make sure you can find it! Awesome! I'll put it in 5th and give it a shot. Thanks so much! JB Link to comment Share on other sites More sharing options...
1-3-2-4 Posted June 22, 2011 Share Posted June 22, 2011 No problem Link to comment Share on other sites More sharing options...
JazzBass Posted June 23, 2011 Author Share Posted June 23, 2011 Alrighty. I got the spring on. It is rather tough to stretch, but I got it on. This is how I did it: Closed the hook on one end of the spring a little more so that it would stay on the knuckle linkage better. Attached the spring to the knuckle linkage. Used a pair of forceps clamped on the other hook to help me manuver it better. Using the forceps to hold the spring, I used a bent (curved) screwdriver and hooked it to the spring hook and using the surrounding parts for leverage, stretched the hook over to the washer loop. Here is the problem: I must have a great deal of play in the knuckle assembly as the stick is over just underneath 5th gear now and to shift into 1st and 2nd, I need to hold the stick quite a bit to the left. When in gear, it's over to the passenger side now. So I want to say that the bushings are worn big time in the knuckle. Is this correct? Is there something that can be done to help that? I've heard of folks stuffing a washer or two to help bring the play back to as center as possible. Any thoughts on my diagnosis? Did I goof something? Thanks, JB Link to comment Share on other sites More sharing options...
