capn_r Posted June 22, 2011 Share Posted June 22, 2011 I just got a car with 14 inch steel pugs and I am missing one of the goofy rump roast washer and nut sets. Are there any out there or is there another solution? Thanks Quote Link to comment Share on other sites More sharing options...
T'subaru Posted June 22, 2011 Share Posted June 22, 2011 I bought pug lugs from 4x4brat http://www.ultimatesubaru.org/forum/showthread.php?t=49131&highlight=official&page=13 Quote Link to comment Share on other sites More sharing options...
capn_r Posted June 22, 2011 Author Share Posted June 22, 2011 This picture shows what I have. (Just not quite enough of) http://www.indysworld.com/80s/general/wheels/pug-centering-washer-lugnuts.jpg Quote Link to comment Share on other sites More sharing options...
T'subaru Posted June 22, 2011 Share Posted June 22, 2011 This picture shows what I have. (Just not quite enough of) http://www.indysworld.com/80s/general/wheels/pug-centering-washer-lugnuts.jpg weird, im above my head here, im out good luck sir Quote Link to comment Share on other sites More sharing options...
mcbrat Posted June 22, 2011 Share Posted June 22, 2011 you've got the pug 504 wheels from the 70's .... no aftermark ones available you'll have to wait it out for a set... you could do 3 proper nuts per wheel, and one non-correct until you find some.... or you could get different wheels... Quote Link to comment Share on other sites More sharing options...
88Subi4x4 Posted June 23, 2011 Share Posted June 23, 2011 I have a Set of lug nuts for the Pugs send me a PM! Reid Quote Link to comment Share on other sites More sharing options...
capn_r Posted June 23, 2011 Author Share Posted June 23, 2011 Thanks Mick, that's pretty much what I had figured. Reid, we will be in contact and see what happens. Quote Link to comment Share on other sites More sharing options...
Yo'J Posted June 24, 2011 Share Posted June 24, 2011 Did you buy that from an art major?! Quote Link to comment Share on other sites More sharing options...
TeamCF Posted June 29, 2011 Share Posted June 29, 2011 Well I looked but did not see what I was looking for. But this link has close to what I used on my 504 wheels. http://www.empius.com/vwcatalog/2011/191.html Look at the "ball seat" lug nuts. I found just washers at a VW shop that let you use regular lug nuts on ball seat rims. Not nearly as good as the correct lug nuts for your wheels. And I had to replace them every time I took the wheels off as they pretty much squished out. but it did offer a bit more bite than just regular nuts with the 504 wheels. Not the right solution, but a hair more holding power. After that I used thick grade 8 washers that I bent to fit the curve of the wheel and beveled the hole on. (better and more reusable, but still got wonky over time). And then I spotted a set of 505's in a local JY for $28 and just switched. (Best solution) Good luck! Quote Link to comment Share on other sites More sharing options...
capn_r Posted June 30, 2011 Author Share Posted June 30, 2011 Thanks for the tips TeamCF, I'm only short one and maybe if this thread gets bumped enough I will find someone that has a spare or spares. I going to do the hub redrill to six lug and run some nissan 15's I have on the car anyway but the rubber isn't bad that I have and at least even being a bastard wheel they aren't 13's. I have run the ball seat adapters on some VW Jetta alloys I have run on my GL10 that I redrilled to 4x100, I will check the fit of those adapters on these wheels. I wonder if there is a chance to machine the 60 degree ( I think) angle to the holes and run regular sube nuts. Thanks again. Quote Link to comment Share on other sites More sharing options...
mcbrat Posted June 30, 2011 Share Posted June 30, 2011 Thanks for the tips TeamCF, I'm only short one and maybe if this thread gets bumped enough I will find someone that has a spare or spares. I going to do the hub redrill to six lug and run some nissan 15's I have on the car anyway but the rubber isn't bad that I have and at least even being a bastard wheel they aren't 13's. I have run the ball seat adapters on some VW Jetta alloys I have run on my GL10 that I redrilled to 4x100, I will check the fit of those adapters on these wheels. I wonder if there is a chance to machine the 60 degree ( I think) angle to the holes and run regular sube nuts. Thanks again. the ball seat adapter is just a "close enough" fix for the alloy lugnuts. and I don't remember the 504 lug holes looking "sturdy" enough to handle a bevel and a reg. nut... Quote Link to comment Share on other sites More sharing options...
