DevC Posted June 23, 2011 Share Posted June 23, 2011 Ok, car is a 92 Legacy Turbo with a 91 Pull type hyrdraulic clutch. I want to swap this out for a 90 n/a push type cable trans, I want to use the existing hydro pedal set/c-master, 00 RS slave/clutch/flywheel/fork and move the pivot ball to the other hole. The mounting holes for the slave are not on this trans, but I can fabricate mounting of some sort easy enough. Anything here not gunna work? Suggestions? Final drive ratios arent an issue. I'm wanting to go RWD without wrecking my Pull-type turbo 5mt. Link to comment Share on other sites More sharing options...
Fairtax4me Posted June 23, 2011 Share Posted June 23, 2011 Ok, car is a 92 Legacy Turbo with a 91 Pull type hyrdraulic clutch. I want to swap this out for a 90 n/a push type cable trans, I want to use the existing hydro pedal set/c-master, 00 RS slave/clutch/flywheel/fork and move the pivot ball to the other hole. The mounting holes for the slave are not on this trans, but I can fabricate mounting of some sort easy enough. Anything here not gunna work? Suggestions? Final drive ratios arent an issue. I'm wanting to go RWD without wrecking my Pull-type turbo 5mt. So you're gonna weld the center diff I guess? Should be interesting. I wanna say the push type slave mounts to a bracket on the engine bell housing, not on the transmission. I'm not 100% positive on that though. Shouldn't be too hard to find pics floating around out there somewhere. Link to comment Share on other sites More sharing options...
987687 Posted June 23, 2011 Share Posted June 23, 2011 It mounts to the tranny bell housing. There should be two threaded holes just to the driver's side of the pitch stopper mount. Link to comment Share on other sites More sharing options...
DevC Posted June 23, 2011 Author Share Posted June 23, 2011 Its not there on this trans unfortunatly, I'm hoping that I can drill and tap what metal is there and brace it with some flat stock to another unused hole near-by. This is just a beater trans setup and not my daily, so I can experiment, I just want to make sure the clutch will work with this tans and fork combo? Link to comment Share on other sites More sharing options...
DevC Posted June 24, 2011 Author Share Posted June 24, 2011 Heres my tranny, one of the holes is allready there that the 00 rs slave mounts too, may be able to drill and tap the other hole, space it with washers, and brace it with another hole near it or something if the metal is too thin. OO rs slave\/ Link to comment Share on other sites More sharing options...
