bgambino Posted June 24, 2011 Share Posted June 24, 2011 I have a rebuilt compressor for my AC. Does anyone know the exact amount of compressor oil that is recommended? 93 loyale 1.8 spfi AND...does it matter whether I pour it into the high or low pressure port? thanks Link to comment Share on other sites More sharing options...
ruparts Posted June 24, 2011 Share Posted June 24, 2011 hi, the amount depends on which compressor your system has, there were several different types used on these vehicles, and i think there should be a plug in the case for adding oil on a dry unit, but intake side if not i believe. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted June 24, 2011 Share Posted June 24, 2011 Only fill it back up to what comes out.. I know it sounds stupid :-/ When i did my AC system in my 95 legacy the FSM showed how much oil went into each part of the system.. I do remember the evaporator took the most. Link to comment Share on other sites More sharing options...
bgambino Posted June 24, 2011 Author Share Posted June 24, 2011 hi, the amount depends on which compressor your system has, there were several different types used on these vehicles, and i think there should be a plug in the case for adding oil on a dry unit, but intake side if not i believe. which is the intake side..the high pressure or low pressure side? Link to comment Share on other sites More sharing options...
1-3-2-4 Posted June 24, 2011 Share Posted June 24, 2011 intake is always the low side Link to comment Share on other sites More sharing options...
