yesyeah Posted June 25, 2011 Share Posted June 25, 2011 (edited) 1999 subaru legacy - How hard are these to do? i got both left and right side inner tie rod parts for $60. Was quoted $100 to install - does that seem "reasonable"? Thanks! Edited June 25, 2011 by yesyeah Quote Link to comment Share on other sites More sharing options...
tcspeer Posted June 26, 2011 Share Posted June 26, 2011 You need to get the inner tie rod tool from Harbor Freight it is around 50.00 dolllars, I done mine with out it but it was a tough job, so I bought the tool for the next job. 100.00 dollars sounds fair if you dont want to mess with it. Quote Link to comment Share on other sites More sharing options...
porcupine73 Posted June 26, 2011 Share Posted June 26, 2011 That doesn't seem too bad. Subaru inner tie rod replacement is not too hard to replace without removing the rack if you have the tool. Sometimes loosening the jam nut is the hardest part. That and getting the blasted steering gear boot to go back over the rack. The lock washer can be reused if you don't have a new one provided it can be rotated to get a fresh spot to bend the ears over. Quote Link to comment Share on other sites More sharing options...
yesyeah Posted June 26, 2011 Author Share Posted June 26, 2011 Thanks guys. Yeah, got the parts, I don't fully want to mess with it. Been hearing / feeling some clunking going over bumps etc, and there is definitely play in the wheels - so this seems like a good bet. I appreciate it - just wanted to make sure $100 for labor on this was good to go. Quote Link to comment Share on other sites More sharing options...
bstone Posted June 26, 2011 Share Posted June 26, 2011 Just remember, you'll need an alignment after you do the tie rods. I am doing both sides (driver and passenger) and replacing both the inner and outter tie rods. I was smart and got the lifetime alignment by Firestone last year, so I don't have to pay for it again. Quote Link to comment Share on other sites More sharing options...
