The oil pan on this project car has a dent where it was high centered. Now leaking about a drop every 20 minutes.
Thought about JB weld, but if I am going to the trouble to remove it, maybe I should just replace it.
What ja think?
well, depending on where the dent is located on the pan, you may want to replace. if the pickup tube is damaged, you could have a nasty oil starvation problem. just ask some of the 2004-2008 EJ255/257 owners!
