Help! 97 Legacy's wiring went *pop*
I was jump starting our EJ22 Legacy a few weeks ago since it has been in storage for a while, when I mistakenly connected reversed the jumper cables attaching them to the battery. :eek: The car made an audible pop, and I pulled them off immediately, but it was too late. No amount charging seemed to bring it up speed.
Later, I took the battery back to Autozone to have it tested. They gave it a clean bill of health. When I went to install it in the car, it still didn't start, but the door buzzer now worked. So, I tried a few other batteries that tested good and they didn't work. I tried jumping, too (the right way this time), but no success. Now, the electrical seems to be half dead.
Here's what I checked:
- power door locks (works)
- door buzzer (works)
- power windows (doesn't work)
- power mirrors (doesn't work)
- air/blower (doesn't work)
- all exterior lights (doesn't work)
- radio (doesn't work)
- instrument panel (doesn't work)
- starter (doesn't work)
I'm thinking it might be some fuse(s) (still checking on that), but do any other ideas come to mind? There's no obvious damage that I have found yet.
Thank you for your help.
you probably blew a ''fusible link'' in the fuse box under the hood, driver's side. (they are the ones that look like a wire loop sticking up.)
a test light will tell you which one or just go to the parts store and get a couple. they are cheap.
or maybe a SBF, slow blow fuse, same location.
