gryhnd Posted June 29, 2011 Share Posted June 29, 2011 Attempting to change the right front stub axle seal on a friends 2004 awd have purchased seals but would I would like to remove bearing retainer in the trans axle and install seal. Is it threaded into the case? If it is and I mark it and count the turns coming out will my pre-load on the bearing be OK when I go back in? Need a good manual any recomendations? TKS Link to comment Share on other sites More sharing options...
Fairtax4me Posted July 1, 2011 Share Posted July 1, 2011 You got the gyst of it. I haven't found a thread with a writeup guide or anything, but there is some info floating around out there. I started a thread looking for info on this subject a while back: http://www.ultimatesubaru.org/forum/showthread.php?t=114265 For what it's worth. Link to comment Share on other sites More sharing options...
