Parking lights won't shut off!!!
99 legacy SUS Had to install a check engine light and sparkplugs,did that hooked the ground on the battery backup and now the lights won't shut off!!Is this a switch problem or should I look somewhere else?
mysterious parking lamp switch that no one ever sees. It exists to run the parking lights without the key on.
Everyone does it.
Mow, if you marker lies are flashing and wont let you start the car, there is a reset switch near the hood lever(if you have alarm)
mystery switches!
