gen 1brat camber plates?
I was thinking about do this. I guess I will start looking into what might work and see if i can make it happen.
If you get to it before i do then make a thread!!! and i will do the same if i do it
also where in Alb. do you live?
Edited by whitesti400
  • 3 weeks later...
Hmmm, I was hoping for a drop-in solution, but I suppose the second-best choice is is anything that will fit in the diameter of the tower. I'm going to have to put the search on hold for the time, so anyone more adventurous should feel free to post!
  • 10 months later...
So clearly I haven't pursued adapting a pair of camber plates. The real issue is the horrendous positive camber these little trucks sport that make going around corners a questionable affair. What other ways are there to negative-out the camber? Any substitute suspension arms that might do it?
