anastij Posted July 1, 2011 Share Posted July 1, 2011 I rebuild engine( all new seals, timing belt and tensioners, heads rebuilt). runs perfect. after about 15k I have been getting these misfire codes. If light didn't come on I would not know anything is happening. The car runs great. I reset light and then 100 miles later the Code comes back. It started out p0304 misfire now it seems to p0301 misfires never get two at a time. Never get flashing cel checked and searched around. Have seen everything from coil PAC to valve problem. Odd thing is my car runs great Checked wires, coil PAC fuel system. Compression OK when rebuilt Help! Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted July 1, 2011 Share Posted July 1, 2011 What did you set the valve adjustment to when the heads were rebuilt? GD Quote Link to comment Share on other sites More sharing options...
anastij Posted July 3, 2011 Author Share Posted July 3, 2011 Set them to the specs in the Subaru factory manual Quote Link to comment Share on other sites More sharing options...
